Nose high on Fox 2.5 (not leveled)
BroncoDEPR
Jorge
Lexus GX470
I'm running the FOX 2.5 PERFORMANCE ELITE COILOVERS and out of the box the rig is running nose high. The ride feels good in general, have hit a couple of gravel roads on Baja mode ..go fast :) nearby but I haven't got a change to flex it at the trails in PA. I'm planning on putting a few 100 miles before adjusting to correct for high and level it.
For reference I have Camburg UCA, ICON steering and RCV axles with ICON rear arms and track bar in my set up.
Ford Bronco Nose high on Fox 2.5 (not leveled) IMG_6642
KABQ
Aaron
Albuquerque, NM
For better advice you may want to correct your title
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I too came here thinking there was an issue with noise, not nose.
AccuTune Offroad
2021 Sasquatch 4 Door, Jeep JLUR, Tacoma
The stock rear springs that come with those coilovers, unfortunately are too light, especially for a 4-door model. We will be offering different springs (2-door/4-door specific), different shaft bumpers/bump stops and piston/valving upgrade if you're interested. Shoot over a PM if you have any questions!
MyDogGoldie
Charles
SoCal
2.7L BD 4D
Are the Fox 2.5" Shocks height adjustable on vehicle (wheels off the ground),
Or do you have to use a spring compressor?
I know my Fox 2.0 Shocks (F150) require a spring compressor (complete uninstall / re-install required) to adjust height.
Also, it appears that Fox Specs different Part Numbers Depending on Which Set-up you have (4-Door vs. 2-door / Sas vs non Sas, see screenshot below of their website)
I am just trying to figure this stuff out. I plan on ordering new Coilovers this week for my Bronco, and want to make sure I do the research first.
I might Call Fox on Tuesday to figure out what they say about it.
Ford Bronco Nose high on Fox 2.5 (not leveled) 2023-05-28_12-18-23
AccuTune Offroad
We highly recommend using a spring compressor to adjust preload on an OEM fit coilover like these, especially when adding preload.
There are different part numbers yes, however the (2) fronts share the same specs and so do the rears.
Feel free to give us a call, we've been getting to know these shocks really well in the last month. 619-722-8555. We also have a bunch of these in stock with upgrade options.
87-Z28
Andy
BMW
Does anyone have any really good photos of the fox shocks, on the bench not installed. Both front and back?
Jsykes
Jonathan
Jps51621!
Sasquatch black diamond
Idk man, that looks pretty level to me, what are your measurements from wheel to fender liner?
Strizzo
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
I saw in one of the Shock Surplus videos that the bump stop on the fox is a bit longer to ensure that 37s will fit without contacting the fenders.
With that in mind, how much would you think would be the minimum amount of lift you could run with the fox setup without constantly being on the bump stops? I have a few height considerations such as parking garages, and family accessibility so I would like to eventually add some travel and improve ride with 1 or 2 inches of lift, at most, and don't plan to go higher than stock tire size. Are any companies kits suitable for stock or close to stock height while offering the features like remote reservoir and damping adjustability?
AccuTune Offroad
Longer than who's?
I don't have specific numbers on lowest possible ride height. When you upgrade to longer travel shocks, they will typically have a longer compressed length than Factory. So setting them at stock height would not be ideal since you would potentially be losing up-travel.Losing up travel would be a loss in performance which is not something our customers are usually looking for. Shocks need proper amount of up/down travel to perform well. So in short, I would lean towards saying no, these Fox/King options are not ideal for those wanting to maintain a stock ride height.
BroncoDEPR
BroncoDEPR
Jorge
Lexus GX470
After a few weeks of use the measurements from tire to bottom of the fender 5.5" front / 5" rear. I'm adjusting the coil overs today and will post new height later on
Strizzo
Houston, Tx
Longer than who's?
Longer than their early versions. I also noticed Icon recommends a bump stop spacer if you run their shocks with 37" tires
Thanks, I'm not opposed to adding an inch or two, I just don't want to run 3-5" because my wife is short and its already tough to get in for her, and I don't want to deal with the issues that much additional lift bring to the table. I previously had an Xterra for almost ten years so I am familiar with the challenges dealing with limited travel in an ifs setup.
Instead of further derailing this thread, I might make a separate thread once I organize my questions better.
AccuTune Offroad
@Strizzo I'm still not sure what you mean with the longer bump stops. Longer than what earlier version? We're talking about Fox aftermarket Performance Elite Series coilovers, correct?
Ground_zero298
Scs michigan
From the set I got built may 23 states for 4 door sas and non sas.
Way I read it they have a 2 Dr and 4 Dr set. 4 Dr covers sas and non sas. I have a 2 Dr and grabbed a 4 Dr set to comp for my added weight.
I couldn’t be happier with the shock upgrade. I actually like how it rides now. Night and day difference. I had to add 2” for height in the rear and dropped a inch in the front.
Ford Bronco Nose high on Fox 2.5 (not leveled) image
