No updates?
buckingup
Jonathan
los angeles
bronco tesla
I have a 24 BD Sas. Purchased last February. It seems like i have never had a software update. Considering most of my electronics update frequently, I’m wondering if this is normal? Is there a way to check what software I have and what is current?
GnormalGnome
ee
PNW
2025 Ford Bronco
Not sure on checking versions, but if you're not receiving updates automatically you probably have that feature turned off.
Go to your Ford Pass app.
Go to Settings, then Software Updates. Verify auto-update is on and a schedule is set.
If you have auto-update off, and don't want to turn it on, I believe you can perform the update from the in-vehicle screen, but I haven't explored that option.
GoHawks63
George
Metro Detroit
2024 Bronco Wildtrak, Cadillac CTS-V Coupe, Roush Stage 3 Mustang convertible
I have a 2024 WildTrak purchased new last January and I too have not received updates and I know I have automatic updates set to on. It's also connected to my home Wi-Fi and the vehicle sits in the garage at home which gets a strong Wi-Fi signal
GoHawks63
George
Metro Detroit
A member on this site checked FDRS if I had any updates pending and he sent me this screen shot.
When I mentioned that I haven't gotten the updates pending, the following was his response.
Just because an update is pending doesn't mean you can initiate the install. It has to be sent from the server and that happens at random. The dealer can do them with FDRS, but they won't because Ford does not pay them to update modules just because they are out of date. You just have to wait for the OTA to come in.
Ford Bronco No updates? FDRS
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
For what it's worth I got mine last August, auto updates on and I've only gotten two OTA updates, both for the window module (couldn't tell any difference after the updates).
AZCoyote
Wiley
Phoenix
2024 Big Bend Sasquatch
Is anyone else connecting their Bronco to their WiFi? Wondering if that helps with update frequency?
GoHawks63
George
Metro Detroit
Mine is connected to WiFi and haven’t had an update even though two are apparently out there.
AZCoyote
Wiley
Phoenix
I had a Ford Explorer a few years back and I could actually download the updates to an usb apply them. Is that the case with this version of sync?
Supposedly it does populate sooner, but I have no way to prove that.
I haven't had an update since last December, although last time I checked with FDRS (like this past Spring) - there was nothing pending. And I haven't heard of any software updates triggering really.
Would be nice if they would fix Sync, but I think they are just gonna concentrate on the new Android sync and just pretend Sync 4 doesn't exist any longer. I mean... buy a new car if you want updates, isn't that how we used to do it?
GoHawks63
George
Metro Detroit
I have done this with my Mustang, but it's a 2016 and doesn't have OTA update capability. I would imagine that the Bronco should have that capability, but I think that other updates, specifically for other components of the vehicle can only be implemented through OTA updates or the dealer.
Not with Sync 4. Your options are OTA, Wifi OTA, or FDRS
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
Since Ford started sending updates OTA 4-5 years ago, very few updates have been sent to any vehicle that requires wifi. In the case of the Broncos, I believe it was only one OTA that required wifi, and that was TCU update 23-PU113-UNX-DC which was only sent to 21-23 model years to fix a config issue in the TCU where the country code got changed to another country rendering the modem useless in the US market.
All OTA's download via the modem whether the truck is connected to wifi or not. The handshake between the vehicle and the server only happens through the modem. The updates that require wifi are congifuration only updates and not actual firmware updates.
Whomer1
Clay
MS
2016 Silverado, 1968 Impala
I got the brake booster update yesterday. Anyone else?
Ford Bronco No updates? IMG_4067
dstanky
Wisconsin
2024 Bronco 4dr Badlands Sasquatch
I have a 2024 Bronco and haven't received any updates since I bought it a year ago. Can anyone check FDRS for me?
rugedraw
Javier
Miami, FL
Unfortunately, due to some recent changes Ford made in their cybersecurity, anyone who runs a VIN through FDRS without being plugged directly into the vehicle runs the risk of getting their account banned. AFAIK, checking for pending updates in PTS is still safe from the ban-stick, but in my case, Ford nerfed my PTS account and I can no longer check for pending updates.
If your Fordpass is connected, message me the VIN and I can check to see if you had any failed update attempts, if your connectivity is working right and if it is reporting any codes, but as far as what modules have pending updates, that I can no longer check.
