No Analog Dial Tach? No Problem!
Murraydog11
Rick
2021 2Dr Outer Banks, Jeep Cherokee
Here's my Torque Plus/Old Android phone tachometer MacGyver set-up: Total cost-$24.95
Added Bonus-Vacuum/Boost-Actual Torque to wheel-Coolant Temp.
Ford Bronco No Analog Dial Tach? No Problem! 20230116_165243
ChrisB351
Shreveport, LA
But theres a tach in the center of the dash. Granted its not very efficient but unless youve got a manual its really not necessary.
Murraydog11
Murraydog11
Rick
No Analog Dial Tach. Sorry, I should have been more specific.
Squatch
Nice if it works for you, but I have some asinine BS dial gauge constantly polishing off the EPA about my instantaneous MPG which is not critical for driving and rather distracting. There should be a dial tach in there, no excuse. I just have to have enough free time and blackmail material to get the NHTSA, lol, to say that a dial tach is a safety requirement for manual transmission vehicles.
Ixr
2022 2DR BASE SAS
If you have to stare at a tachometer while driving manual you shouldn't be driving a manual.
Edit: op has a automatic so his post checks out.
Cetacean Sensation
PNW
Bronco & Bimmer
Honestly, even if was set up with the horizontal digital bar like on MOTEC dashes I'd be fine.
The vertical bar with two speedos is just genuinely asinine design. Ford really should've fired the UI designers who came up with it, and their bosses for approving it.
Murraydog11
Murraydog11
Rick
Can you ever really know too much about what's going on in your engine?
Cetacean Sensation
PNW
Bronco & Bimmer
Generally yeah, but sometimes you're just in an environment where you can't hear what's going on. And having a tach I don't need to look at in order to parse information from is a good thing. That's why needle gauges and motec style digital tachs exist, you can get the necessary information into your brain by having them in your peripheral vision.
Are you really gonna tell me you've never looked at your tach while driving?
rtazz17
Connecticut
2022 Ford bronco big bend
Yes when it makes it not fun to drive anymore because youre caught up in your tachometer… disclaimer,I used to be like that but my bronco isnt a deleted 6.7 diesel so im not concerned anymore about temps and egts and tachs but hey if it makes you happy thats what counts..
Lowcountry Bronco
William
South Carolina Lowcountry
Rarely, I shift when I get to the meat of the torque and then move to the next. About the only thing I look at is the speedo to make sure I'm legal but most of the time I am knowing the gear I'm in and the way the vehicle feels/sounds.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Nice!
paperboy
Nelson
Vancouver, BC
2019 Passport
An old thread but I would like to revisit!
Do I need an analog tach? No.
Do I want an analog tach? Yes!
What did you tap into to get a reading? Does the dashboard tach still operate?
Anymore photos/video with it in action?!
Thanks.
paperboy
Nelson
Vancouver, BC
2019 Passport
BigMeatsBronco
Allan
2021 FE 2 door
If that device shows the actual oil pressure it would be worth its weight in gold
