NAPA Maxi Trac 300LPM dual cylinder air compressors - list of identical/rebranded compressors, some in stock
thd
FL
2014 Camaro SS 1/LE
I was about to purchase a Smitty Built compressor which just needs to be connected to the battery and the tire you want to inflate. I was hoping the Trickflate would be that easy but I see "This compressor is not designed for 1 tire at a time and should be used with a 4 tire hose system" so now I am a little confused to say the least about what is included in the kit and what I need to add.
What is the duty cycle for the pump? I see the duty cycle drops to 2 minutes when inflating one tire.
Does the pump include a way to pump all four tires at the same time or do I need to assemble the hoses to make it work?
Will the Milton S443 3-in-1 chuck allow the filling of smaller items (sports balls, air mattresses, etc) in addition to a single tire?
What is the duty cycle using the Milton S443 check when inflating a single tire?
What configurations would require the use of the Trickflate pressure switch and US style automotive coupler conversion kit or the Trickflate 2 way hose manifold with 0-200 PSI pressure gauge?
Jdc
Jon
Massachusetts
Bronco Badlands
This is the one I bought https://morrflate.com/shop/morrflate-multi-tire-air-kits/morrflate-quad-4-tire-air-kit/
There are multiple options out there including DIY instructions if you're interested.
Free2Roam
Heading back to the desert
2023 Bronco
Sneak peak! My compressor mount for 2DRs will be out in a few weeks and a 4DR version shortly after. This is designed specifically for Trickflates but should also fit Maxi Tracs.
I have your trickflate with your 4 way air up hoses and gauge. Is this mount for my 2 door available or coming soon? Has anyone wired this compressor up to a bronco yet to give wiring details?
Thx
JayP
2023 Big Bend Sasquatch Mid
Anyone have a mount for these for the 4 door soft top Broncos?
Rydfree
Benny
Alabama
Is this 2dr mount available yet ?
TireFlate
www.tireflate.com
Yes, and the 300 LPM is the same as the 10.6 CFM claims. Interesting . . .
I'm in for a group buy...👋
They are not all the same, some are smaller heads on the compressor! The good ones are 60mm heads. Make sure you're getting the right one as they look very similar. Stop by and see ours!
Jviz4u
SOCAL
Ice-Mountain special
Should that work for Napa Air Compressor also?
RynoRanger
Chuck
Phoenix
azbluey.com
2.7L Badlands NS 4dr
@popo_patty just dropped a video about the 'clones' of carstell dual air compressors. He talks about the slight differences and who "paid for the tooling" for some of the newer features etc. Worth the watch.
