Comparing portable twin cylinder air compressors with set target pressure option
crabbz510
Abby
Greensboro, NC
2023 Bronco, 2dr
Been doing a lot of research on what makes all these compressors different from each other.
If someone could correct me if I am wrong, I would really appreciate it.
Morrflate (https://morrflate.com/shop/air-sour...s/morrflate-tensix-psi-pro-compressor-batch1/)
EZFlate (https://ezflate.com/products/pre-order-m-o-a-b-auto-air-10-6-cfm-portable-dual-air-compressor)
Thor's Lightning (https://thorslightningairsystems.com/products/lightning-bolt-totalcontrol-true-dual-air-compressor)
Most of these compressors run about the same price, give or take $30. The 4-hose systems using comparable hose diameters and lengths manufactured by these companies also run about the same price for a given vehicle wheelbase, give or take $30.
So what makes them all different / better than each other?
All I am able to find in terms of differences is that the Thor's Lightning has a modified circuit board to keep the unit from overheating if you're only using a single hose versus the 4 or 2-hose system to distribute air out.
There are lots of real-world tests and trail videos of folks using these systems with great results. I'd just like to have the on-paper differences before making my final decision this holiday season.
Mike T
Brandon SD
2023 Ford Bronco
Naoa has theirs back in stock and had like 20% off this last week. Picked it up for 119 plus tax. Shipped free
Rydfree
Benny
Alabama
They all look like the same just painted a different color .
I have the Morrflate Ten-Six Pro and it is a hoss. No complaints here.
j_marinelli
Spring Branch, TX.
cr117
PNW
Bronco, EV6
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
One is red. One is green. One is ... you get what im saying. They are all the same just rebranded under their own name brands.
We stock the MORRFlate ones here: https://www.4x4truckleds.com/morrflate-tensix-psi-pro-12v-portable-compressor/
Because we also sell their multi-tire inflation hose kits.
Unless it's an ARB or ViAIR most compressors are just copies of each other with a different name.
RynoRanger
Chuck
Phoenix
azbluey.com
2.7L Badlands NS 4dr
Popo Patty just dropped a video comparing a lot of them
