Maxi Trac Dual Compressor (NAPA)
mcinfantry
Lee
Louisiana
Badlands 2 door
If I ever see my bronco and you tell me there’s room under the hood I’ll fab a mount
Werkedperformance
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
There’s room under hood. For sure! I just want it here.
DREWR13
DREW
ATLANTA GA
2003 Miata....
Interested to see the new cubby. Got my MaxiTrac and tested today. Very fast fill time for all tires at once.
ryridesmotox
Ryan
Murrieta, California
21 Bronco Black Diamond
You're going to need a serious wire powering that. I was thinking like 4gauge at least of pure Copper, not that copper clad aluminum wire. 20 feet is enough with a few feet of extra.
WuNgUn
Ontario Canada
2 door Squatched
Video says alot about initial performance. Long term????
I found a second video that re- confirmed these test results.
20% off right now too if you buy 3 items.
I got the digital deflator, and trash sack. All Maxi Trac branded.
Remeber also, absolutely no warranty on this.
Werkedperformance
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
Im cool with that. I can buy 6 for the cost of an ARB.
I verified the video. I finished in half the time of an ARB dual pumped jeep at the terrain park. Not much left to do except see how long it lasts.
Christmas is holding back my new tub for the cubby at the moment. Not enough time
In the day
WuNgUn
Ontario Canada
2 door Squatched
In the day
If only NAPA sold them in Canada 😩
DREWR13
DREW
ATLANTA GA
2003 Miata....
Got mine the other day and a quad inflator setup. Took my sas tires from 18psi to 38psi in under 3:30mins. Pretty impressed.
ryridesmotox
Ryan
Not even worried
I went to start my bronc... forgot I didn't have the parking brake on. Hit the clutch and rolled onto the compressor.
I was air down so I hoped that it would work at the end. Filled up my rig plus another and didn't miss a beat. It won't stand on the base anymore because it's so bent. But it still works. If a 4500 lbs vehicle putting a tire on it and rolling over it won't kill it, I'm not worried
KosmicKid
Bronco, Jaguar XFR-S, Raptor, MKZ
I got the Maxi Trac after a friend at work suggested the Ez-flate M.O.A.B They were sold out so a little bit of Googling led me to Desert Armor (the one in red) and they too were sold out.
A bit more Googling led me to NAPA and the Maxi Trac
I did see this was available in green from another company: try googling 90A or 150psi tire portable tire compressor that's how I found the Maxi Trac
Very impressed, and of course durability is an issue, (as well as the other two) but for the money well worth it.
Gamecock
I just ordered the NAPA compressor after watching the video and seeing I could get it for $82 with the current 20% off. Nothing to lose at that price...I may try to mount it under the hood, or may just leave it loose so I can use it on other vehicles and my tractor.
richs184
New London, NC
SF
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Will the Maxi Trac fit on this mount?
No the MaxiTrac is not a small air compressor (which is why it fills up tires faster). So it won't fit. It's too big.
richs184
New London, NC
SF
Appreciate the response. Thank you
