MPG - what is yours?
TyGuy40
Ty
Austin,TX
Triumph Bonneville
On 93 Octane:
Mine is pretty subpar.
14-15 City, if I am lucky.
21 Highway
2.7L 2-door, non-sas 33"s KO2s
I also try to drive in ECO mode a lot. Doesn't seem to help much.
reigny
Karen
Delray Beach, FL
Ninja 650, 2003 Honda Shadow Ace
The tire size makes an extreme difference in MPG. My stock OBX was getting 20.5 MPG. I switched out to 33" KO2s and i now get 17.5 MPG. I think the bigger the tire the lower the MPG. And i'm ok with that!
DD214
Western Mass
2018 JLU Sahara, 2015 Pilot, 2022 Bronco
OBX Sas with 2.7 with 200 Miles so far - 17.3.
PrepVet
North Central WI
A bunch.
2.3, auto, 4/door, non sas, rear locker. No mods. Lifetime 19mpg
Ford Bronco MPG - what is yours? 64973CC4-5D40-4926-83F8-62B24F9DA5DF
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
I should have also added - mine has 3.73 gears and does not have 4A so it is always in RWD only which I'm sure helps a bit too.
I’ve got the 4.7 gears. Probably makes a difference. 😆
RubyRedGT
Greg
Pittsboro, NC
21 Bronco. Sold the 1968 and 2015 mustang GTs
17-18 with 2.7 Badlands with front level lift and 305 Toyo ATs (34”). But I drive the speed limit and in mostly mixed driving. No high speed highways.
Sven
West Yellowstone, Montana
67 Bronco,75 F250 CS,88 M35a2c,
17.9 on the cluster. 2200 miles of mixed driving. 91 octane 2.3/auto BL SAS at 6700 feet. Lots of idle/warm up time. it was 8 degrees this morning.
bronco2drga
Nick
Georgia
2021 Bronco 2 Door
On 93 Octane:
21 Highway
I feel the same way, 2.3 manual base upgraded to the black diamond steelies with all terrain tires that come on those. I think I went from 30 in to 31.6 in roughly.
I haven't been pushing the Bronco hard because I'm on the at first thousand miles, 65 on the highway, not going super high on shifts, etc. The best I've really seen is about 18.6 miles per gallon per the dash and per my hand calculations.
I run regular gas and I try to stay on the Eco mode. Most of my driving is done in rural Georgia so a lot of two lanes running about 55 mph.
I know most people will say well don't buy a Bronco for miles per gallon, but I did expect the EcoBoost to do a little bit better.
One thing to consider is that you are losing some mileage on your odometer due to increased tire size. A quick calculation I did was that something like 2 in increase entire diameter is 5% odometer loss, but do your own math mine might be off. That could potentially add a couple miles per gallon.
JBlanco
Julio
Charlotte NC
2023 Bronco BaseSquatch, 2023 Tesla Y Performance
Currently sitting at 16.3 on the lie
O meter. Just got the speedo corrected this past Sunday so we will see if it goes up or down. 2.7 outer banks non sas with badlands wheels and tires 33” bfg
I literally drove 1.2 miles to work with stop signs and lights tho.
I assume vehicle doesn't even get up to temperature?
Does that concerns you?
My wife's commute (the Bronco will be her daily) is 1.7 miles and the Wrangler barely gets to temperature in the winter. I change the synthetic oil once every 3k miles to make for the additional gas and water in the oil.
Jason74
Lake Arrowhead, CA
'22 Bronco Badlands
20.8 lifetime. 91 Octane
2.3 Manual 2DR Badlands, non-SAS., 80% highway, 20% street.
MayhemMike
Mercury
2.3 auto 2D BL non Sasquatch. Only have 400 miles on it so far but 20.6 per gallon is the number. Regular fuel. Pencil and paper calculation.
Sledge
Germantown, MD
‘13 mod’d Flex, ‘14 bmw i3, ‘93 mod’d Volvo 240
What are you getting in real world driving? Add your model, engine, trans, Sas or not. Before I got mine I really wanted to see real world numbers. Not complaining….. smiles per gallon.
Still waiting on my bronco, but will share an experience with the 3.5 eco boost that’s in my 2013 flex. I did an axle-back exhaust system (from MRT)plus a tune (from unleashed) and my mpg increased substantially! I knocked 1.5 seconds off my 0-60 times, BUT when I didn’t hot-foot it my mpg was also remarkably improved - as much as 2mpg at non-highway speeds which makes sense when considering turbo performance at lower exhaust gas loading. I would expect the same phenomena with the twin-turbo eco boost in the bronco, and am planning to do the same.
