MPG - what is yours?
Aviboy97
Connecticut
16.8mpg.
5,500 miles
2.7L OBX, 4A
Upgraded 285/70/17’s vs the stock 255/70/18’s
there was a .5 mpg drop when I added the larger tires.
broadicustomworks
Hanging Rock, North Carolina
18.7 -18.6 depending on if I stay in boost and takeoff harder some times more than others.
Driving in normal mode, not ECO, as I have found the lack of power in ECO doesn't net me the MPG increase I was hoping to offset the lack of takeoff.
2.7 4D BL Sas. A.M. wheels, factory Sas tires.
Hopefully this summer I'll be adding a pedal commander and possible tuner to it, will see how that impacts it.
I don't baby it necessarily, but I also don't leave every light or intersection like I am at Talladega either.
I have found that the more harder launches and lack of pedal awareness does drop it down to about 18.4.
Adding a BOV keeps me aware of when I am more heavy on the boost, as I have the MPG gauge up on the side vs the boost gauge most of the time.
8,000 miles in, avg since bought 18.1 (first 1200 miles were driving into heavy central/north TX winds) , avg for the last 3K miles since oil change is the steady 18.6-18.7. 5W20 Mobil1.
Destroyer
2002 Chevy SWB NBS, 2022 Bronco
I still struggle to understand just how these numbers are as low as they are for the Bronco. For reference, my JK has a NA 3.6L motor which makes less power then the 2.3 or the 2.7, even within every motors "efficiency" range. 5 speed tranny in the JK vs the 10 speeds in the Bronco. 4.88 gears in my JK which are taller and less fuel efficient then even the tallest 4.70's in the SAS Bronco's. And finally, I have super heavy 37x13.5 tires...I think full tire/wheel weight is somewhere in the 110lb per corner. And yet, I can consistently pull down 18.5 mpg highway and 15.5 mpg around town. Consistently fuel up after fuel up average 16.8mpg. Don't understand how the Bronco is literally more efficient in EVERY single relevant category I can think of and yet it's less fuel efficient across the board
Murfman
Colorado Springs
2021 WildTrak, Cyber Orange soft top
What are you getting in real world driving? Add your model, engine, trans, Sas or not. Before I got mine I really wanted to see real world numbers. Not complaining….. smiles per gallon.
19ish, 2.7 auto with squatch pkg. I have gotten as high as 20.7, in eco mode on the highway.
85 octane at 6500+ elevation. I keep the auto start on as it has no effect on driving, just being stopped.
internationlriders
Josh
Alberta Canada
2021 Bronco Badlands
2.7 Badlands SAS 4dr with Panda Power tuner on stage 5. We drive pretty spirited in my house (wife and I) with about 60/40 city/highway driving and so far over the last few thousand KM we're at 13.6L/100KM which works out to 17.3MPG. Also we have only used 91 octane since we got it.
Aviboy97
Connecticut
2.7 Outerbanks non-sasquatch and I can get as much as 20.5 city and 24.5 highway/road trip.
Normal goat mode.
I’ve got the same car, and I’m not even close. Do you have 4A?
Tmurder1776
2021 Bronco Base
2 door base 2.3 auto and I'm getting 23.5 during warm weather and it drops to about 21 during cold snaps. I've seen 24, nearly 25 when driving to Moab. I always drive in eco and almost always under the speed limit on the highway.
Mrpenn46
Nebraska
Badlands - Cactus Gray
Avg: 16.41
Min: 14.41
Max: 19.05
I use the app "FillUp" to track it and I've found that the dash display is 5-10% optimistic from actual calculated values. Driving behavior is 90% 2 lane highway ≈50 miles one way @ 65-70 mph.
These numbers cover 5350 of my ≈8250 miles on the vehicle.
Here in Nebraska the wind plays a massive factor in MPG, headwinds absolutely kill MPG.
Badlands, Non-Sas (33's) , 2.7L, Auto, Hardtop
internationlriders
Josh
Alberta Canada
Avg: 16.41
Min: 14.41
Max: 19.05
Totally agree on wind, we also get a lot of wind here in Alberta and driving a brick like this up a big hill into a headwind and you are in boost the whole time to maintain any momentum.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
I assume vehicle doesn't even get up to temperature?
Does that concerns you?
My wife's commute (the Bronco will be her daily) is 1.7 miles and the Wrangler barely gets to temperature in the winter. I change the synthetic oil once every 3k miles to make for the additional gas and water in the oil.
I start it before I go anywhere in fact I have it on a schedule in FordPass. I also start it before I leave work and let it warm up. It absolutely concerns me and one major reason in switched out if a diesel superduty when I started driving less.
WreckItRussell
Jack
Wills Point, Tx
Old and Busted Cherokee
I've got a 2.7L 4DR SAS Badlands and Im getting 15.6. I spend a good chunk of my driving time on the interstate going 80+ mph.
