Mountains2Metal's New Flip Down Attic Shelf
Ghecko90
Glenn
Wilson, NY
2021 4D Bronco Badlands Soft Top
Looks like a great solution. Curious if there is any rattling issues?
Any M2M partners out there that can give the 5% discount or Vet discount? 🤠
I have a squeaking issue when it's loaded. I haven't figured it out yet. No noise when the tray is empty, except over a good bump. I think that is expected though. I have a noise that is like Styrofoam inside of a box when you are trying to pull it out. Super annoying.
Smalltomato
Cary
Georgia
I had the same thing but it only happened when the shelf was pushed as far as it would go toward the passenger side. Not sure if yours is the same.
Mountains2Metal
Mountains2Metal
Nick
Eastern, NC
2012 F-150, 67 Bronco, 94 Range Rover
Anyone have the SSV works speaker pods and can confirm that this fits with them?
I do! Works with the large speaker version of our attic shelf.
Bikes&Beer
Justin
Atlanta
2023 OBX SAS
I can confirm it works with a JTOP. Brackets go underneath the top nicely. You may want to replace the bolts. They are hex head. I can see potential wear long term. I plan to swap mine out.
Great, thanks!
Night Horse
Dan
Ooltewah / Cleveland, Tennessee
2022 Ford Bronco Badlands Sasquatch / Lux
When I saw this, I realized it would be a nice addition, so I ordered one. Installation was fairly easy, but I did need to manually bend the right side bracket a little. No matter what I did, before the slight bend, it would not latch. Since the parts looked straight, my guess is that is wasn't the product, but the Bronco possibly having a slight difference in it from the factory. Nevertheless, after I applied a slight bend, it latched perfectly. I did add a few wraps of electrical tape to the latch pins to deaden rattles and then added felt tape to the sides of the tray to prevent another possible rattle if the tray came into contact with the brackets. I'm super picky about rattles and that's all on me. Having said that, the attic is a very nice addition to Night Horse and I highly recommend it.
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_20240608_184344
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_20240608_184351
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_20240608_184353
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_20240608_184401
TerryB
Terry
Banning, CA
24 Badlands Sasquatch, 2019 Jeep Wrangler Rubicon
I would like to get some opinions from those who have installed it in regards to the sturdiness. Watching videos of opening and closing it seems to be kind of flimsy. Like they should have added another horizontal bar across it to stiffen the platform.
Night Horse
Dan
It does flex if one side is dropped. However, I ditched the carabiner clips they provide and just reach up and use my middle fingers to release the latches while holding the tray with both hands. It then lowers down easier in one fluid motion. It's easier, to me, than using the carabiner clips. I shut it the same way, with both hands and it latches fine.
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
It is sturdy, no worries there.
It does rattle a bit on bounces but I recommend
Felix808
SRV CA
Can some get some dismissions? Looking for the height of the rack as well as height from inside the rack to roof.
Also looking for width & length at the widest & narrowest areas.
Appreciate it 🤠
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf Attic Shelf
contented
Karl
Central Fl
BMW M2 Competition
I have one and don’t think there’s anything “flimsy” about it. When you load it with 40# of stuff, it’s easy to grab in the center, lift and latch. When you go to unlatch it, you’re reaching in, arms extended and spread wide apart, pressing the latches and letting it down w/o dropping it. That is difficult for this old man. If you’re young with lots of upper body strength, not a problem. So I unlatch one side, then the other and lower it down. There is enough play in the hinge pins and latches that when one side is unlatched and dropped down there just is a very little bit of twist in the basket. In the second pic, the right side is unlatched and hanging on its own, perhaps an 1“ below the latch.
IMHO, making it stronger so it doesn’t twist at all just adds unnecessary weight and cost. I’m really happy with it and as you can see I have the lower shelf too. YMMV
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_2533
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_2543
