Mountains2Metal's New Flip Down Attic Shelf
contented
Karl
Central Fl
BMW M2 Competition
Wondering the same thing. @Mountains2Metal can this be installed with a Jtops bimini? The Jtops covers the rear rollbar. Looks like your brackets mount to the top rollbar. It may work if the M2M brackets are installed first and the Jtops goes on top of those brackets. But not sure about the clearance for the Jtops as it wraps around the rollbar and may interfere.
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_2486
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_2480
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_2478
PatagoniaDan
Georgia
Really like how this product keeps items out of view and secure - also a good anti-theft device of sorts.
Does anyone know if this is compatible with the AAL MASS Cargo Shelf? I believe it uses similar mounting holes in the roll bar. I’d like to see if I can have both installed at the same time.
Footer
NJ
2023 Bronco
Any feedback on if it will allow the use of a Toplift Pro to take off the hard top ?
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
Perfect. Thx for the pics @contented! Exactly what I wanted to see.
this shelf seems so much more useful than a shelf that hangs in the middle of the cargo area. For me anyway.
Felix808
SRV CA
Looks like a great solution. Curious if there is any rattling issues?
Any M2M partners out there that can give the 5% discount or Vet discount? 🤠
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
98% of the time - no rattling issues - driving around town when you hit a bump like rail road tracks or similar there's a rattle - I'm working on figuring out where exactly it is to eliminate it and I'm sure I will. But other that its really pretty awesome.
Felix808
SRV CA
Thanks @DriveAllNight & @Smalltomato.
How much effort would be required to remove it for when I want to jettison the hard top? I have a roll n jack that would need it to be removed to lift the top.
Thanks again 🤠
BD6G
Everglades
IN
24 Bronco
Everglades
The top lift pro will not fully seat into the rear to use it. I tried up and down positions. However I’m still more than happy with it. I just have to lift and slide it back some on the TLP and all is good.
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_5459
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_5460
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
I installed mine this week. Was missing some bolts but my local farm supply came to the rescue. M2M credited my account for the hassle. I have rather large hands so like everything else I work on it is a little more challenging but it was an easy install. After I got everything lined up I did a few minor adjustments and only hear what I have stored in it make noise. When it is empty I don't hear any sounds coming from it. Shocks would be nice but they are a bit of a pain and would just add more hardware and adjustment points.
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_8071
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf IMG_8070
Footer
NJ
2023 Bronco
Thanks for the info BD6G.
Looks like the rear pads don't quite fit under the rear top, do you lift it on the window seal and then slide it back on the lift ?
BD6G
Everglades
IN
24 Bronco
Everglades
I just sit inside the rear lift up and slide it on the TLP real easy to do not to time consuming
flashpunk
San Francisco
Received and installed mine in about 20 mins tonight! Was a bit fiddly to get the bolts in without removing my hard top, but im pretty happy. Very nice product, and excellent use of space. Thank you M2M!
mvilla
San Francisco
4-door Badlands Bronco w/ Sasquatch package
Anyone have the SSV works speaker pods and can confirm that this fits with them?
Ghecko90
Glenn
Wilson, NY
2021 4D Bronco Badlands Soft Top
Does this work with a Jtop, or does that get in the way?
I can confirm it works with a JTOP. Brackets go underneath the top nicely. You may want to replace the bolts. They are hex head. I can see potential wear long term. I plan to swap mine out.
