M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted)
Cody@Mountains2Metal
Cody
Wilson, N.C.
2021 Ford Bronco 2D Manual
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) HOnzb9Vf-uDvbKREgbsG9dDVRcZ6ThYAIrd5ocLjRESHgqariQ
We at @Mountains2Metal are excited to announce our Rear Cargo Tray for the 4-Door Bronco 6G. This is a product both designed AND produced in the 🇺🇸USA🇺🇸. This has been a work in progress for a bit now, but I think it was well worth the wait. We have made it compatible with our Rear Roll Bar MOLLE as well as our Rear Cargo MOLLE Panel. (all of our 4-Door Bronco 6G rear cargo products use the same Main Support Bracket *See note below for more information*)
A common question we have been receiving is "Does the tray lock in the vertical position?"
Our answer is; there is not a latching mechanism to have it lock in the upright position. Since the gas shocks are strong enough to keep it up, if you decide to leave it up while off-roading, dune-bugging, speed bump-racing or whatever you guys use your Bronco for.
  • Sold assembled, just bolt in and go
  • Does NOT hit back seats on ALL reclining settings
    • Follows factory lines with plenty of clearance everywhere
  • WORKS WITH: (4-Door)
    • Factory Soft top
    • Factory Hardtop
    • Bestop
  • No drilling required
    • Just simple hand tools
  • Did I mention it was made in the USA?
    • IYKYK
NOTES:
  • In addition to that, if you already have both Main Support Brackets installed then you will not have to purchase any more for the any of our 4-Door Bronco 6G rear cargo products (All three of these products share it, the only difference is that the Rear Cargo Tray Requires both).
One more note, if you are going to get your first M2M rear cargo product and do not have any Main Support Brackets, please buy them on the little add-on menu on the rear cargo product you are looking at purchasing as seen below: (it will save you money)
Install Video
Written Instructions are on the website now
Pictures:
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) CMR_1071__54382.1674665795
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) DSC06692_1__54230.1674665794
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) DSC06676_1__70794.1674665793
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) DSC05894__34671.1674665760
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) 885_Main_Support_Bracket__21408.1674665760.jpg?c=1
Dimensions:
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) 1674843308760
Customer Pics:
If you are a customer and have some pictures, post them in the comments!
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) S6ilOEl0GdQgyeLhluX_PhI4FACu_ztlMxhHcP-YgyP2wzZBLA
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) 3jw0LOm2SFrfPqBjXW3cRBCduGoaX4R_S-cfVzvc1jSPTCzoxw
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) image3
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) image0
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) image1
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) 1674843309153
nomnom
Alan
Colorado Springs, CO
2021 Basequatch
Thanks guys for this great product! Good customer service and communication, installed fast and easy, carries all my recovery gear and some.
A lot of people are missing out by skipping out on this!
SCFireChief
Harry
Beaufort SC
2023 Bronco
I like this tray, can I add this if I already have the attic tray installed? Any issues having both?
Ninjak
Miami
Though I do not have these products, I think there would not be an issue with both as they mount in different places. I do believe I have seen a post where someone had both of these setup. I like the attic tray, but as I have a slant back top coming, I do not believe I will have the room for it. Also, I do not have the rivnut holes on my 21.
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
I really like this, I have one (another brand) that I use all the time, but doesn't flip up. I know we are a much smaller segment, but is there a 2 door version in the works?
contented
Karl
Central Fl
BMW M2 Competition
contented
Karl
Central Fl
BMW M2 Competition
Here you go with the attic tray down.
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) IMG_2533
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
I have both. No problems.
I guess my question would then be if I have window molle panels as well as the cargo molle panels could it be installed?
contented
Karl
Central Fl
BMW M2 Competition
Here are a few more pics. Hope these help. I would say you could mount the window panels ok, but not certain how much stuff you could attach.
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) IMG_0832
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) IMG_0833
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) IMG_0829
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) IMG_0830
BD6G
Everglades
IN
24 Bronco
Everglades
They do all work together from window molle to cargo Molle and the attic and lower tray. I don’t have the lower cargo molle due to me having the ford factory slide out table but it will all work together.
Ford Bronco M2M THE FIRST CARGO FLIP UP TRAY (hydraulically assisted) IMG_9733
contented
Karl
Central Fl
BMW M2 Competition
What kind of stuff do you put on the molle panels? What’s kept me from getting the window panels is it seems the size of items (thickness) is limited when mounted, especially If one wants the shelves to rotate.
BD6G
Everglades
IN
24 Bronco
Everglades
I keep a small Gerber Hatchet additional flashlights, for awhile a thinner first aid kit (have a bigger one now) and at one point had soft shackles strapped to it with MODL straps and my winch controller all that’s changed now though once I load it back up for the year here within a week to get ready for Super Celebration Tennessee I’ll try to get some photos of the load out.
contented
Karl
Central Fl
BMW M2 Competition
Thanks. I’d love to see pics.
