Mountains2Metal's New Flip Down Attic Shelf
SCORPSCPO
Henry
El Cajon, CA
We are thinking of this for our Starlink. Gotta make sure the role bar won’t be in the way when the tray is flipped up. Great idea regardless.
This is exactly what I use mine for and it seems to work well.
EasternSierra
Bill
Sacramento metro, California, U.S.A.
2025 Bronco Badlands 4-door 7MT, 2023 Ford Transit Connect van
The installer for my Armadillo top found that this shelf interferes with the top to the point where they can't both be installed as-is. They had to modify the shelf to make it fit: Post. The modified shelf works well, though.
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
did you put your starlink in a case or power with a battery/plug in? I was thinking of doing that as well but putting it in a case to protect it from rattling around. Also maybe the magnets to secure it up ther. Thoughts?
SCORPSCPO
Henry
El Cajon, CA
I put the antenna in a Revolink mount with 4 magnetic feet to hold it in place. I’ll only use it on the go or once I set camp, so I power it with the OEM inverter plug in the back of the center console. At camp, I use a jackery with a USB C adapter cable. I’ve considered using a battery to direct power it, but haven’t used one yet.
DaddyO
Jules
Austin, Texas
I don’t seem to get any power from the plug in the back of the center console. I’ll double check it when I return home.
Jim05
Culpeper, VA
www.guildva.com
2023 Badlands
I believe I have figured things out. Time will tell... The rattle was solved with nylon washers at the pivot and a combination of heat shrink and slightly thicker nylon washers at the release. I had a squeak that was driving me nuts that turned out to be at the release. I solved that by retightening the mechanism bolts and lightening the load in the shelf. I used to keep my recovery strap and shackles up there (40 lbs?) and now have only lighter things (extra clothing, ground cloths, etc) there.
