Missing hardware for slide-out tailgate
Gregus73
Greg
Los Gatos, CA
2024 Silverado 2500 HC, 2023 Bronco Heritage, WRX
Hi all,
Just received the new slide-out tailgate, and missing bolts and side brackets.
I called Ford parts and asked if they can send the missing pieces and was told no.
They offered to create an airbil, however the box was in very bad shape and to be broken down in my recycle bin. I also did not anticipate parts to be missing. Honestly a first time for me.
I offered to buy the missing pieces and was told that they do not carry them separately and cannot be purchased.
Do I just buy a huge box and toss all of pieces in the box and send it back to them with their air bill?
Just irritated as the package took a month to arrive to me.
Will not be buying from Ford parts after this lousy customer experience.
Had better luck with Chevrolet parts.
Any other thoughts, not thrilled about wasting $1200.
Also called Ford customer care and got nowhere. Again much better experiences with GM.
RagnarKon
Ford Bronco, Escape, Focus
What pieces are you missing now?? Sounds like you're missing C, D, and a few of the bolts? If so, which bolts?
Ford Bronco Missing hardware for slide-out tailgate 1722393709225-r
Gregus73
Gregus73
Greg
Los Gatos, CA
Hi, I am missing c & d which are both c-shaped brackets, and all of the bolts which are e & f. Which totals 6 bolts.
RagnarKon
Packing it up and sending it back for a replacement is probably the "correct" answer, but since you don't have the package anymore and packaging costs money, may not make sense.
SO... in case you didn't want to deal with the return:
  • C: M2DZ-78402B59-A
  • D: M2DZ-78402B60-A
  • E: W721961-S439
  • F: W709055-S439
Can be ordered at your dealer's parts counter.
Gregus73
Gregus73
Greg
Los Gatos, CA
Thanks so much.
Johnkn
Maryland
'66 GT350, 68.5 CJ Mustang, B2, Viper, Pantera,TRX
Ask if you can purchase another, and return your original in the 2nd box for a refund....
good luck....
HP11
New Hampshire
2013 Boss 302 (sold) , 2023 Ford Bronco WildTrak
I feel your pain and I hope it works out for you. Anything you can do to avoid the return/replacement process through accessories.ford.com should be avoided. The return process could take months and if you used Ford Rewards points it will be a nightmare getting them back, and if you do, they will not return all your points used. Yes, that was my experience and I will never purchase anything from accessories.ford.com... ever.
Gregus73
Gregus73
Greg
Los Gatos, CA
Yep I used rewards…buying the pieces at the dealer just seems easier…..I am pretty handy once I have all of the needed items and can take it from there.
Luckily, I did not order a soft top or something really expensive. Lesson learned to avoid accessories.ford.com.
Thanks again, this gives me a solution to move forward with.
Ninjak
Miami
WoW OP that is horrid. I ordered from Ford as well, and I can attest to how the box comes. I had it shipped to my dealer, and when I went to pick up, I was amazed on how bad the box was. Luckily, I had a second box, and the part box was taped inside that box.
Good luck with getting your other parts. The tailgate is worth it.
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
That is odd. I ordered the performance front tow hooks and they each came in a box, wrapped with bubble wrap. They were in another box wrapped in paper and that box was in another box. This is the second time I ordered a part that came in multiple boxes.
flip
Phil
IN
www.ruxerparts.com
Fords
We've had this happen twice and was able to get the parts replaced through the FAD. Depending where it came from, they will need a copy of the invoice in order to claim it from Ford or whomever the vendor packing it Ford is using.
Gregus73
Gregus73
Greg
Los Gatos, CA
Update:
Ford is looking into this to see what they can do. Fingers crossed.
I called a dealer parts department and the needed parts would run me $180 minus tax. If Ford fails, prepared to just order the missing parts at my own cost, and avoid Ford accessories site and move on from this.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
I heard about this happening to people before. Was nervous when I got mine but all the parts were in there. The box was pretty beat up. The cover for the slide out tailgate was also a little melted. But certainly nothing worth returning over.
Hope you get the missing parts free. The slide out tailgate is totally worth the hassle
Johnny Mo
Westchester County, NY
teachu2shoot.com
Update:
Did you try disputing with your credit card company? That chargeback usually gets someone's attention.
Gregus73
Gregus73
Greg
Los Gatos, CA
Update: Ford is sending the missing parts out to me as expedited. I should be getting the parts by Monday or Tuesday next week.
They made it right.
Thanks for giving me the part numbers as well, that helped Ford in getting this corrected.
