Mishimoto catch can first results on 2.3 engine
TXAG96
Tyler, Texas
'20 Bullitt, '01 Boxster, '87 TBird Turbo Coupe
  • Thread starter
  • Banned
  • #1
So after about 800 miles and about a month of running their catch can, here’s what I’ve been able to collect.
It looks to be a little more than a teaspoon which is about 5ml in Canadian dollars.
What’s more surprising is the apparent “gunk” in the bottom. See photos
Can was installed at about 3300 miles and first oil change was at 3800 miles.
Appreciate any feedback.
EDIT: after wiping the can out, I could not see the solids on the paper towel.
Ford Bronco Mishimoto catch can first results on 2.3 engine 575A2CBD-E427-4DEE-A4F9-424E82E2CEB1
Ford Bronco Mishimoto catch can first results on 2.3 engine 40C722B3-F7F3-4537-83F1-038F040C981B
BrentC
Brent
Calgary, AB
2019 F150 Sport, 2021 Bronco Badlands
The gunk is likely an emulsion consisting of a mixture of condensed water out of the air, oil, dirt and any other substance getting into the crankcase.
DogHauler
Chuck
2022 Badlands Sasquatch 4dr 2023 Black Diamond 2dr
Did you clean it before you installed it? "Gunk" should not happen unless it came from the new parts, just typical crankcase vapors.
TXAG96
TXAG96
Tyler, Texas
  • Thread starter
  • Banned
  • #4
Can was VERY clean prior to install. I'm just a tad bit surprised to see this after less than 1000 miles. Very worth it in my mind..
Now my OCD will go into overdrive watching this thing.
nomnom
Alan
Colorado Springs, CO
2021 Basequatch
I haven’t found any instructions on installing besides on a ranger, was it an easy install?
TXAG96
TXAG96
Tyler, Texas
  • Thread starter
  • Banned
  • #6
The instructions are on their site but it’s not the easiest to navigate to…..
It’s not terribly difficult. You need to remove the driver side tire and inner fender liner.
Have patience as the little black screw like rivets don’t always come out easily.
Mostly a blind reach for the connections.
Take your time and expect at least one slightly bloody Knuckle 😂
330SMG
Dennis
Hurricane Alley
16 F150 ,89 325i and 72 Dodge Charger SE
The bigger story is you waited 3800 miles for a 1st oil change on a new engine.
BigMeatsBronco
Allan
2021 FE 2 door
This is needed for the DI engines. Not necessary for the newer 2.7.
jasonkosi
Jason
Chilliwack, BC, Canada
I’ll add with my first can empty after about 1200km. Hard to picture but I’d estimate it around 20ml give or take, little more than a tablespoon. All in all glad I installed the catch can, feel much better about this not going through the intake
Ford Bronco Mishimoto catch can first results on 2.3 engine 93503DA4-D153-4832-94A0-B9C21EE78C5A
BigMeatsBronco
Allan
2021 FE 2 door
I did say they are needed for the 2.3...thats NOT false information 👎
If I had the 4 popper, Id buy a can!
No I don't like seeing folks buy some doo-dad that's unnecessary and promoted by manufacturers as being necessary when it's clearly NOT very beneficial for engines with port injection.
drew707
Ford Explorer
To your credit, the 2.3 already comes with an oil separator too
Blksn955.o
Greg
Wentzville, MO
bumping thus and adding my results.
Added my catch can at ~2,800 miles and just pulled to dump and check at 4,064 miles. So ~1,200 miles.
Ford Bronco Mishimoto catch can first results on 2.3 engine 20220319_134637
All cleaned up
Ford Bronco Mishimoto catch can first results on 2.3 engine 20220319_134927
Hands down if you own a 2.3L get a catch can. Thinking double this amount went thru the engine before I put this on wishes I had it sooner.
Rusty Sheckelford
Rusty
LA
Can you explain to a noob what a catch can is and where/why it's installed?
Also why are brand new cars leaking oil?
