Mileage range issues
timp
Tim
Aledo, TX
2023 Black Diamond 2dr
When I first bought my Bronco (2.3L, 2-Dr) in November, the mileage range at fill up (with 87octane) was 320. I ran a little experiment with premium octane from multiple brands (Chevron, Shell & Valero) and after the last couple of full ups, my range fell to 285. It hovers there a little longer it seems, meaning I’ll drive a few miles before it starts ticking down. Has anyone experienced this before? Is it the fuel or is my equipment failing?
JakeMangan
Jake
San Diego, CA
2022 Ford Bronco
I’ve got the 2.3, I’ve seen a decline in fuel efficiency in the past month or so as well
JFelty
Stroppe
Minnesota
Lincoln Corsair Hybrid (Plugin)
Stroppe
Winter Blend gas. All my trucks do/have done the same.
Agree 100% my Dad worked for a refinery for 20 years and mentioned the switch to winter blend every year.
555-RGNE
Pop. 196, Texas
2022 Basequatch 2dr 2.7L
Yep, winter blend mixed with remote starting on cold mornings means my mileage has dropped from 16-17 down to 13-14. I looked at my range after I filled up the other day and laughed because it was the same as I used to get in my old '91 Bronco. :LOL:
Alanp970
Alan
2023 4 Door Base Sasquatch Hardtop
I’ve always watched my fuel economy closely (on all my vehicles) and I’ve never seen winter blend fuel affect my mileage as much as with my Bronco. Especially the discrepancy between indicated mpg and actual hand calculated mpg.
Bodge Garage
Kris
Millwood WA
1994 Land Rover Discovery, Jeep Gladiator
I saw a drop in my mpg as well. I suspected the fuel blend but after a tank of E0 it was the same. I assume now it is just the parasitic drag exacerbated by the colder temps.
SHANUT
Craig
Hermann, MO
It’s a big square block with oversized tires, and a very tiny engine, so any differences will be magnified on a vehicle like that. Whether winter fuel blends or driving habits, or letting your vehicle warm up more in the winter time – it can all affect your mileage.
OscarHTX
Houston/TEXAS
I fill up my 2.7 with 93 octane (usually shell v power+). When I bought the Bronco in August I'd get between 410-420 miles of range. The last couple of fill ups its been 385ish.
MPGs also went down from 20.3 to 19.3.
Valhalla
Valhalla
Chattanooga Tn
my 96 gets 12 mpg
Ford Bronco Mileage range issues 20160922_151125
MadMan4BamaNATL
Ray
Atlanta
You guys are always hilarious to read about all of these mpg discussions for a rolling brick off-roader. We proper 2 Dr guys fill up with whatever and have a posted range of around 245mi. Highway is more, yes, but it’s 245 on a good day.
Suck it up fellas, this ain’t a fuel efficient vehicle. That’s what you get with literally EVERY other SUV.
Let us wheelers have at least ONE or two toys to play with. Geez….. :)
Ducati1098
You get more on the highway? My mileage drops like crazy on a long highway road trip. I’m lucky to get 200. That probably has a lot to do with me going way over the speed limit and 37’s though 😂
AZ_Liberty
2007 Expedition
If you live in an area with Winter Blend gas, then you can expect an 8% hit to mileage due to the ethanol.
We see no difference here, because we use "winter" blend year round and have for a decade.
Steed76
Chad
IN
Subaru Ascent, Jeep Cherokee
Winter blend fuels have a higher concentration of Butane in them. Reid Vapor Pressure (RVP) also plays a factor in that it the measure of how a fuel evaporates at any given temp. Its a fine line. Ambient temp plays a role. I've lost about 1.5mpg from my normal 19mpg due to Much colder temps here in Indiana recently, warm up time etc.
One more upgrade
Joe Mogush
22 Tesla Plaid X 22 Escalade
You are right; my mileage has drastically dropped also. I know it can't be the 38's, lift, armor, 5.13 gears. The reason I get 10-11 MPG has to be the Winter blend.
Ford Bronco Mileage range issues side
