- Kevin
- Feb 24, 2024
- 39
- 887
- 1,568
- Chesapeake, VA
- 2024 Bronco Everglades 4dr
- Everglades
I found my in-cab noise over on the passenger side. The right/front MIC top removable roof panel latch's black plastic trim cover was very loose (the one in the front corner)
I removed it and the issue is the design.......not the parts.The left front is loose/sloppy too, but no noise. I'd be embarrassed to call it a day with a design like that.
When they're firmly clipped in, they're still loose fitting. If all else fails, I'll put foam in them to take up the slack.
What's troubling is the 2 metal mounting clips each one uses are not mentioned on the parts list.
When I look it up, every model only lists a 2-door application in the description. They ought to be the same.........but this is my 4-door.
https://parts.applefordwhitebearlak...jbyZ5PTIwMjQmdD1iYWRsYW5kcyZlPTItN2wtdjYtZ2Fz
