Looking into Portals what do people think?
87-Z28
Andy
BMW
Since this thread was initially created we finally got the opportunity to wheel with other broncos on hard trails, both with and without portals, and the other brands of portals. At this point I’m not convinced they’re the ultimate bolt on solution compared to long travel. Certainly they have their place, but with social media trends it almost seems like they are more of a status symbol than anything else. Gucci purse for your mall crawler. 🤣
The portal rigs all seemed to start bouncing sooner on the same obstacles compared to conventional builds. Particularly those that still have rubber components in their control arms rather than full heim. Shock tuning might also play a factor there - hard to know as none of the shocks had been dialed in yet for the portals.
Scrub radius issues are real. The portals do affect the ability to steer on high traction surfaces when you’re aired down. More forces will be applied to the tierods as well. You’ll really need to be picky on the tierod upgrades to ensure they have a good failure point or you might break the rack itself (saw it twice) if you have an upgraded housing.
The increased leverage on suspension components is also something you’ll want to address. Double shear UCA mounts and stronger UCA’s at a minimum. One rig with Tibus portals snapped the uniball on a UCA while pushing up a rock maybe 1.5 feet high. (Certainly fatigue was a contributing factor from everything it had done previously)
Noise isn’t an issue with any of them
Serviceability and parts - steel can be welded, on the trail even. 7075 aluminum isn’t going to happen. If you break it you’re waiting on new parts to arrive. I’m told werewolf does try to use as many off the shelf parts as possible, but there are still proprietary parts associated with them. That applies to all of the brands though. One werewolf owner is pretty sick of the leaks. They might have over tightened the stubshaft during the install but it’s not certain at the moment. They just know there’s a leak. I’ve seen plenty of werewolf portals that didn’t leak. We had issues with 74w leaks from the stubshaft seals and fill plugs but that all seems to have been fixed .
Driving the werewolf bronco I could definitely feel the additional gearing reduction and weight from the steel. Stability felt a little better than ours eveb though our bronco with 40’s was still lower than theirs on 38’s. But I believe they’re also wider in addition to being much heavier. Initially I saw the extra weight as a drawback but if you’re getting your suspension revalved for the portals anyway then might as well enjoy the weight if you’re not a baja guy.
The gearing reduction saving your axles seems to be blown a bit out of proportion. Recognizing that driving habits play a role, there are plenty of owners running the recommended 38” tire size and still breaking their axles. We’re on heavy 40’s and have yet to break anything, but wifey is usually pretty soft on the throttle. So that helps.
lots of fantastic info here for anyone thinking about portals. From someone with a good bit of experience with a portal Bronco.
very interesting observation that the portal trucks tend to be bouncier. You are probably talking about more difficult obstacles only? At some point the shocks most definitely need to be tuned differently as unsprung weight increases. Just not sure when that is. Interesting to think about.
NDM_84
Nedim
Richmond, Virginia
Camaro SS
This sounds like a great plan.
IMO unless you're doing some hardcore rock crawling on a regular basis portals are NOT worth the $$$. Period. Full stop.
I hardly need any more than Sasquatch lol but u know how it is, it's always about going bigger getting the look, and increasing capability. More of a want rather than need, but I totally agree. Real true to size MTs 35s with a bit of a poke and proper shocks and UCAs, should be good to go. If you get the steering rack and tie rods, it should be an indestructible setup.
SierraBronco
You’re going to give poor @ScLeCo PTSD talking about indestructible steering racks 🤣
ScLeCo
Springfield
Charger Hellcat
Yeah, not at all indestructible. If anything but the 74 weld housing breaks you will have to pay for it. Plus the hassle of pulling the rack shipping it to 74 weld and then waiting for them to repair it and ship it back.
It gets expensive real quick.
I believe the best set up is the ford performance rack with the billet end cap/bushing and the ford performance tie rods. You want the tie rods to be your fuse, they are cheap and easy to replace.
NDM_84
Nedim
Richmond, Virginia
Camaro SS
Will look into that, I already bought the Icon tie rods when they were on sale 2 years ago and just have them laying around for spare part purposes. I'm worried the Ford steering rack may not be good enough but it's def cheaper at $1300 compared to $5500 from 74Weld.
SierraBronco
More difficult could be a decent description. We probably all recognize that anything is eventually going to start bouncing in the right circumstances, but was interesting to see all the vehicles taking the same line and how they reacted. Almost every bronco had the RK four link, and all the portal broncos had it as well. And it certainly didn’t seem coincidental that the portal bronco’s were more prone to bouncing, even those with the factory rzeppa driveline. After noticing this I watched the werewolf bronco to see if it was any worse than the others with the taller lift but it was tough to say if there was any difference there.
B22-2023
Houston
Meaning add 74 Weld Stage 1 to the Ford rack? That’s what I’m planning (on HOSS 3.0 w/Icons).
ScLeCo
Springfield
Charger Hellcat
That's what the 74 weld stage three is, the ford rack wrapped in their housing.
Their housing which did NOT prevent damage to said rack. What's the point of paying $5500 if you're just going to have to buy a new rack anyway and then pay to have it put into the expensive housing that did nothing to prevent the failure.
It's up you man but I have $8k in to my steering rack already and I've had it less than 6 months. If it fails again I'm getting rid of it and just doing what I recommended to you.
ScLeCo
Springfield
Charger Hellcat
I'd ditch the icons and just use the ford performance tierods that come with the rack. Like I said earlier you want the tierods to be the weak link. I think the icons might be a bit too strong.
NDM_84
Nedim
Richmond, Virginia
Camaro SS
I hear you, of course they claim that stage 3 is amazing and fixed all the issues and if you don't have their housing it will break because Ford doesn't address the main issues, I'm like the worst thing is if you pay a lot, but it still breaks lol. They did that one video where they explain why their housing is they key to a good steering rack but I don't know as it's just a claim. I may just stick with 35s and that's it and maybe add that Ford Performance steering rack. Is the Ford Performance steering rack from the Raptor or what?
SierraBronco
I gave our spare rack we carry on the trail to a buddy that broke his, and the spare rack he had at the house has the Icon tierods. Can confirm-those suckers are beefy as hell.
Was going to pull the RPG tierods and go back to single shear with RK tierods with the smaller bolt, but we might have just a touch too much droop for those with the current setup. Don’t want to break the mount off the portal so we’ll hold off until we redo the suspension to lower the lift and optimize travel while also adding limit straps.
87-Z28
Andy
BMW
the max bending stress in a circular rod is a function of the diameter to the third power. So small changes in diameter can really beef up the tie rods.
it would be very cost effective and stupid simple for the oem tie rods to be increased in diameter. There is a reason this is not done. Nobody wants to break a tie rod, they just want it to be weaker than the rack.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
I have the 74Weld portals on mine, and their rack. I have wheeled jeeps and full size Broncs for years. Nothing compares to the 6G on portals in my experience. The ground clearance is INSANE. The road manners are practically unaffected. If not for the terrible fuel mileage, and the big leap I gotta take to get in the thing, it would be a nice daily. I don't own a trailer for my 6G, I drive it anywhere I wheel it. I personally haven't had any reliability issues...they have been bulletproof. There is some maintenance to consider...they recommend changing the fluid in the boxes at each oil change. While I feel this is probably an abundance of caution, I have been following that schedule. My Bronco now well EXCEEDS my skill level in capability, and I am 100% happy with it!
B22-2023
Houston
Ok thanks for clarifying - but on the rack, if I have HOSS 3.0 isn’t that the same as FP as far as the housing and end cap ?
