Looking for advice
Maury
Maurice
Hi,
took the Bronco in for a front pinion leak under warranty. Got done in a few days, so far so good so I went to pick it up. Driving home it started to smell like gear oil. Yep, leak was worse. Took it back, waited, eventually got told they were going to replace the whole diff. Ok... After about a month, finally have it back. Given what happened before, I crawled underneath to take a look. Brand new diff indeed, but then I noticed this
Ford Bronco Looking for advice 1712262675160-ih
Yeah. Service rep told me to just keep an eye on it, but I'm not sure I will trust this too long. Now given past experience, I am also leery of taking it in again, don't want to wait another month...
WWYD?
BlueBronco
DFW
I guess you have to be more specific, what did you notice and what are you supposed to be keeping an eye on?
615_Bronco
Cheatham, TN
2022 Bronco 2D BL, SAS, MT, & 2015 F-350 DRW
lower ball joint?
Is it under warranty? I’d take it to another dealer, if not, replace it myself.
Maury
Maurice
It's one with the arm, otherwise yeah I'd do it myself. Unless I can replace the boot only? Anyone know if that is possible?
Fordified1
Bob
Mid South Texas
Make them replace it. Torn boot means short life for the ball joint. Get them to order the part and then make an appointment when you know the part is in stock. Specify you’re only willing to leave it there one day.
Felix808
SRV CA
lower ball joint?
You have to replace the whole lower control arm as it's non serviceable :( Looked into that one before.
OP, take it back to your dealer. Good luck with it 🤠
Maury
Maurice
Urgh... Yeah I'll probably do that, but first Moab it's the perfect time of year.
Bschurr
NY
That’s unacceptable and clearly a total failure on the part of the servicing dealer. How did they let it leave the shop like that?
Felix808
SRV CA
When are you going? We've got a small group that will be out there 4-30-24 to 5-3-24
userdude
Denton, TX
2023 2dr Badsquatch
Can somebody circle the issue in the photo? 🧐
Maury
Maurice
Not sure, we usually make a weekend out of it on a whim. If there's a group going I can plan around that maybe. Is there a thread for that trip?
Felix808
SRV CA
There is. unfortunately, the search button is banned at work but if you search Bronco Safari 2024 & my username you'll find it.
(Edit) Or hit me back channel ;)
We'll be running the following:
Gold Bar Rim 6 / Little Canyon 6 Tues 4-30-24 Lockers F&R
Flat Iron Mesa 6 Wed 5-1-24 Lockers F&R
Onion Creek 2 Hideout Rt Gateway – Castleton Route Thurs 2 5-2-24
Maury
Maurice
:cry:
Not to mention the down time. I feel like warranty work took a back seat.
Maury
Maurice
I'll search, thanks! I have lockers F&R, they do come in handy.
