lift help
Tomleo67
Tom
Mass
22' big bend 4 door
Thanks to everyone on here for helping me so far with my 22' non sasquatch big bend build and answering stupid questions. I'm looking to add a couple inches to accommodate 35's. This is a street build, won't see much dirt if any maybe some beaches. I was gonna do the rough country 2" lift which is simply 4 hockey puck type spacers. I see there are a few other low cost solutions and I was wondering if anyone has any experience with any of these products and the pros and cons of each. this is a street build so I'm looking more for a nice comfy ride not interested in stiff trail setups but not sure if spacers, collars, or shocks would be best for my needs? TIA
https://www.rpgoffroad.com/product/21-23-ford-bronco-base-model-sasquatch-spring-perch-collar/
https://www.roughcountry.com/product/configurable/ford-bronco-lift-kit-591141
https://zoneoffroad.com/products/4-...ck-package-models-only?variant=40804082090072
https://www.extremeterrain.com/read...ch-rear-sst-suspension-lift-kit-69-21210.html
https://www.extremeterrain.com/belltech-bronco-3-inch-suspension-lift-kit-152601bk.html
Aonarch
Jack Hoff
MT
Tons and tons of threads on this.
BlueBronco
DFW
Sounds like spacers or perch collars will suit your needs. I would be very wary of anything cheaper than RC, which isn't looked upon very highly in the off-road community. Remember, you get what you pay for.
Another consideration is gearing. What do you have? If 3.73 it is probably best not to go bigger than 33's or it will be a dog off the line.
Edit. And no, you won't need to upgrade the steering rack or brace the tie-rods for your intended use.
Tomleo67
Tom
Mass
22' big bend 4 door
thank you! yes 3.73 gears. Probably doing the procal tune also tho
PWillette
Parrie
Maine
For your intended use I'd just look for a set of non-SAS Badlands or SAS take-offs. You'll get the lift, much better ride and won't have to replace the UCAs.
Tomleo67
Tom
Mass
22' big bend 4 door
are you talking the shocks?
PWillette
Parrie
Maine
KillerPenz
North East
Just don't get take offs from a 2021 or 2022, they seem to be the ones that are rotting out. I have a 2021 BaseSquatch and already had to replace (1) rotted out shock, the other 3 aren't looking too great either.
And if you are going to spend anywhere from $300-$600 on takeoffs, I'd say take a look at the Bilstein 6112's. Can find them for around $950, they work with your coil springs and are adjustable.
MNBigfoot
MN
A non-sas Badlands can run 35's with the right off-set rims....... It has .66" of lift.
Tomleo67
Tom
Mass
22' big bend 4 door
i have a non sas big bend. new 20's are 0 offset
Caleb@PandaMotorworks
Caleb
St Louis MO
C'mon, get the Bilstein 5112's as the upgrade. Stop jackin' around. Ain't no puck or spacer gonna make the Hitachi's feel smooth and buttery.
https://performanceparts.ford.com/part/M-18000-B1A
What he said ^, but I would recommend Eibachs over the 5112s. They are perfect for daily driving and still very capable for mild-off roading
Cheaper, ride similar, fully height adjustable, limited lifetime warranty
I have these available for $1550 shipped right now :) Would be happy to get you setup!
Tomleo67
Tom
Mass
22' big bend 4 door
works for base big bend non sas? hows the street ride quality, not looking to offroad much if any...
