lift help
Caleb@PandaMotorworks
Caleb
St Louis MO
works for base big bend non sas? hows the street ride quality, not looking to offroad much if any...
Yes sir! Street quality is amazing. Super smooth/soft ride. They feature a progressive spring rate which makes going over bumps and ruts a breeze.
Tomleo67
Tom
Mass
22' big bend 4 door
Just don't get take offs from a 2021 or 2022, they seem to be the ones that are rotting out. I have a 2021 BaseSquatch and already had to replace (1) rotted out shock, the other 3 aren't looking too great either.
And if you are going to spend anywhere from $300-$600 on takeoffs, I'd say take a look at the Bilstein 6112's. Can find them for around $950, they work with your coil springs and are adjustable.
they are $2400 for a full set assembled :oops:
Tomleo67
Tom
Mass
22' big bend 4 door
They come fully assembled?
Just bolt in?
They are adjustable?
Can I run 35x20's?
Do I need to remove crash bars?
Caleb
St Louis MO
Just bolt in?
Can I run 35x20's?
Yes they come fully assembled, ready to be swapped. You just bolt them right in.
They are fully height adjustable up to 4", which is plenty to fit 35s
Hard to say for sure if you will need to remove the crash bars. If you do, high clearance options are available such as Massive and Icon, or you can just run no crash bars.
Tomleo67
Tom
Mass
22' big bend 4 door
ok sounds good! you are in the running. will be making a decision soon. Thanks for all your help!
KillerPenz
North East
6112's?
You don't need fully assembled. Just the shocks, you reuse your springs.
Looking on ebay I can't find them. I had seen the 6100's (what I would need) for $950
Maybe I'm wrong but I assumed the 6112 reused the spring like the 6100's. If not, I'd look at other lift kits like Old Man Emu or something adter the experience I've had with Bilstein. But you can always just go with a Puck lift for cheap.
Ford Bronco lift help Screenshot_20240308_183836_Chrom
socaldux
SoCal
2023 Ford Bronco
I just went with the 6112's and Icon front control arm on my non-sas Big Bend. It gave me 4.5" lifts when adding 35" MT Baja Boss tires over the old 33".
Tomleo67
Tom
Mass
22' big bend 4 door
LOOKS GREAT!!!
