License Plate Light Flicker
Figmo
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
When you disconnect the plug on the passenger side, does it completely kill power to the license plate light?
That is correct. Disconnecting drivers side has no visible effect on license plate light. But disconnecting passenger side turns it off completely
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
I had issues getting my parking sensors to click back in. I sprayed WD40 directly into them, like shoved the nozzle in there and sprayed it in until it was foaming out, I wiped the excess away and without letting them dry, plugged them back in
It worked like a charm, maybe that’ll help?
Yeah I’d say this or dry silicone spray. I know you greased the heck out of it with dielectric though so I dunno.
There is also a rubber gasket in one side of the plug - make sure that’s intact and hasn’t come out of its track and is jammed up in the top of the plug or something
Figmo
Figmo
Figmo
Frenchtown, MT USA
I did spray with mass air sensor cleaner - but who knows, maybe WD40's the trick? Dark and snowing right now but I'll go out in the AM and give it a try.
Hell, right about now I'd piss on a spark plug if I actually thought it had a chance of working
