LCA Skid Plate Creaking
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Best way to fix the creaking is take them off. The LCA are strong enough and don't need the protection anyway.
The LCAs themselves are strong, but most of us use the skids because of the bolts/nuts are vulnerable.
  • Like
Reactions: 0ne
Stonetree
Stonetree
Ron
Pittsburgh
2021 Bronco Wildtrak
So, I took the LCA skid plates off again, and will leave them off this time. But, I did take a picture underneath. There are wear marks on the bottom of the LCA's where the skid plates were touching. See the highlighted areas in the picture. Maybe this is where the creaking is coming from? Just a thought, because I put enough rubber on those top skid mounts to make sure they weren't touching metal to metal at all. And, they still creaked.
Ford Bronco LCA Skid Plate Creaking 1685389593024
dennispascua
Dennis
Carlsbad, CA
I've been following this thread for the past few months. My left LCA skid plate has also been creaking. It's so loud, it's embarrassing. ASFIR sent me rubber gaskets for the bracket bolts after I emailed them. I've removed and re-tourqued the skid plate four times and the creaking keeps coming back. I give up. I removed them and will buy the new Metalcloak ones when they're available. Good luck👍🏾
Ford Bronco LCA Skid Plate Creaking 20230601_211157
ne2000
Nathan
St. Louis
www.instagram.com
Bronco, Mustang GT
I took mine off today after contemplating you picture a bit. I too had rub marks there and a little in the front. I decided to buy a thin hdpe Sheet and riveted it on the skid where it would make contact with those areas. It wasn't much of an ordeal besides getting the right size rivet. You can drill through that aluminum like nothing. I'll check in after a few Weeks with status.
Ford Bronco LCA Skid Plate Creaking 20230709_173437
omi205
BoJack
Austin
This seems to be with asfir specifically, right?
ne2000
Nathan
St. Louis
www.instagram.com
Bronco, Mustang GT
I've heard of at least one other brand doing it, can't recall which, was in the forums somewhere. edit: on page one of this thread someone said Dv8 is doing it too
0ne
Nate
CO
Flex
I’m of the opinion that the creaking is inherent with the sandwich style mount where the lower strut mount hardware has to effectively clamp load the strut, lower control arm and the skid plate.
OddBall88
Joseph
Ford Bronco
I had the creaking noise on my Asfir skids and used some graphite lube spray and seems to have fixed it for now. We will see how long it lasts.
Tex
Cliff
San Angelo
Wouldn't this simply rub on the rivets at that point? Or is there a different contact point?
ne2000
Nathan
St. Louis
www.instagram.com
Bronco, Mustang GT
Contact point appears to be much closer to the edge, see dark areas, from what I saw after install the rivets aren't touching.
Ford Bronco LCA Skid Plate Creaking 20230709_180816
Tex
Cliff
San Angelo
Ah, gotcha. Yeah that kind of rubbing needs addressed before you get fretting corrosion and whatnot on your LCA.
ne2000
Nathan
St. Louis
www.instagram.com
Bronco, Mustang GT
Checking in after many months and a few offroad trips. The polyethylene solved my creaking issue. I can't recall hearing it once since I installed. This was the material I used that I cut in pieces shaped as you see in the picture using a cutting tool. Just make sure you get the correct length rivet.
Ford Bronco LCA Skid Plate Creaking 20230924_182948
  • Like
Reactions: 0ne
