redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Cool - thanks for the reply. Do you have it hooked to the battery? Worth doing? Noticable improvement?
Never ran it otherwise. It was also only $10 when I got it. Seemed like a no-brainer.
gaaangs
Ohio
Jeep
Just did it yesterday.
1. The access from the driver footwell into the engine bay is a rubber membrane located high up the footwell above your left foot. I used an Xactio knife to slit it.
2. Push the naked end of the wire through. Once the end is through, you will see it poking out when you look in the engine bay. Pull it through. Secure the wire in the engine bay with wire ties (see pics)
3. I’m assuming you’re using @plugnplaykits harness wire. The appropriate couplings on the amp side are self explanatory.
4. You need to get to the amp. Mine is under the steering column on the metal plate.
5. The power wire couplings plug into the amp. The harness joining the amp to the acm plugs into the power wire couplings.
6. CHANGE THE COMPRESSION SWITCH TO OFF(3rd switch) as per Kicker tech support.
7. Attach the ground wire to one of the screws securing the metal plate. ( i guessed on that one)
8. Cut the wire loop on the inline fuse that came with the wire. Use the provided butt connector to join the fuse to the power line.
9. Attach the wire ring connector (provided) to the other half of the wire on the inline fuse. Attach that to the screw of the bracket sitting on the battery positive terminal.
9. I used the Xacto knife to cut a space in the red rubber terminal cover to give access to the power wire.
That’s it. I went into this whole install having no idea what I was doing. @RagnarKon will attest to that!
I’m embarrassed to say it took me 11 hours. The time suckers were wresting with the center HVAC panel…🤯🤯🤯🤯🤯🥵🥵🥵🤕🤕🤔🤔🤬🤬…getting the harness acm connector end attached to the acm, and figuring out where I was putting the harness wire, and getting it to the connecting harness to the amp. Not to mention 3 calls with Kicker support(fantastic) and 3 calls with Joe at @plugnplaykits 🙏🙏👍👍. Joe, you might want to include my explanation of the power wire with the harness. Any experienced installer will know all this, but many of your customers probably aren’t. Feel free to use my pics if you'd like.
I did not have to pull the center console (@RagnarKon awesome video) . I managed to stuff it all in there behind the HVAC panel under the radio. Very tight, but doable.
if I’ve done some things here that someone with experience reading this has an issue with, PLEASE comment.
Hers my ask for help on a few things…
1. The pod speakers(Kicker 4”) sound awful. Dull…flat…”distorty”
2. Though I’ve read people are satisfied with the stock kick panel speakers, I think they sound like shit. Recommendations?
3. The car chime sounds when pushing the radio buttons is way too loud now!
These are my current Forscsn settings.
727-01-01. 382B. 2AF1. 00AE
727-01-02 0900. 000D. 0047
I am going to take them back to original as built. I am running a 6.75” kicker sub with the fusion amp. Doing that will turn that off.
I am going to take the gains to 0, and rerun the pink noise calibration. I am then going to adjust the gain controls, but not nudging to the limit lights firing. I can’t take the volume above 10 at the current settings! That might help with the chime volume.
I will then change the Forscsn setting to activate the sub xxxx xAxx xxxx.
BIG QUESTION…What is the difference between the as built settings between the 6 and 7 speaker settings? Since my truck came with the sub delete(SDARS), but I am now running a sub that is essentially Fords sub setup, I’m not sure what to do here.
I still don’t know what the impact is on having the speakers set to either Soeaker, Speaker/Tweeter, or just Tweeter. I’m not swapping any more speakers, other than upgrading the kickpanels.
im going to finish this today, some some quick feedback would be appreciated.
Huge shoutouts to…
@RagnarKon @JimV @plugnplaykits @gaaangs … and anyone I’ve missed that contributed to the ‘firehouse’ education and help. Hopefully I’m reaching a point where I can contribute in kind.
Thanks for this write up - is helpful. Did you notice any difference in sound from before and after the hookup to the battery? Or did you not run the amp/stereo without the battery hookup first?
Also, I would purchase/upgrade the new kick panel 6.5 inch speakers now that you have the amp installed. You will def see a benefit with upgrading them now that you have an amp. More mid bass for sure. I put Kicker KS's down there and they sound pretty good.
Also, also - now that you have an amp and more power going to those 4 inche speakers - I'd put bass blockers on them. I found that at higher volumes there was some significant "clapping" going on - to the point where I damaged one of my speakers and have to replace it.
ILoveToDrive
Larry
Copake Lake, NY
2023 Bronco Badlands Sasquatch, Porsche Macan S
What bass blockers did you install? I’ve got 600hz in the dash, but none in the pods. I agree with you, especially since I have the sub.
gaaangs
Ohio
Jeep
I got these - its bass blockers and wiring harness all in one:
2021+ Ford Bronco or Maverick 4" Speaker Wire Connectors w/300Hz Bass Blockers | eBay
If you have them on the front then you should be good - up to you if you think you need them on the pods. I threw them on just because when I went really loud there was some more clapping and I didnt want to jack up another speaker. Better safe than sorry.
redone17
Cold Spring, NY
I had 600 for almost a year (that’s what Crutchfield suggested in Aug 2021). Went to 300. Much better.
You don’t need them in the pods. That’s counterintuitive. They are already restricted from the head unit. That’s what you are adjusting in Forscan to remove the filter.
ILoveToDrive
Larry
Copake Lake, NY
Did it improve the overall quality of the soundstage? And, did you rerun the kicker 200.4 calibration?
Since I'm now running the sub, should I be starting with Forscan's 7 speaker As Built, or 6 speaker as built? I'm confused in terms of the choices between Spear, Speaker/Tweeter, and Tweeter on the speakers.
gaaangs
Ohio
Jeep
If you remove the Ford EQ in forescan then the pods pick up more bass - hence the need for bass blockers. I still am not sure they are NEEDED but I put them on there just to be safe.
redone17
Cold Spring, NY
Set it for Speaker.
I’m running 6.5” Memphis MJP6 and I turned up the gain a couple of notches. No blockers. They sound incredible.
gaaangs
Ohio
Jeep
Set it for Speaker.
You are using 6.5s in the pods, not 4 inch speakers in the pods. WIth the 4 inch speakrs and the Ford EQ turned off, at high volumes I found the 4 inch speakers a bit distorted. Just my set up, though.
Does anyone know what the default setting is for the pod speakers? Speaker, tweeter, etc? I am not even sure these settings matter once the Ford EQ is turned off. I feel like that's the point of the Kicker Key amp - it does the EQ optimization for us.
You mind posting your forescan settings for 727-01-01 and 727-01-02?
ILoveToDrive
Larry
Copake Lake, NY
Were the kick panel speakers installs a pain in the ass? I need a break!
ILoveToDrive
Larry
Copake Lake, NY
Set it for Speaker.
Are these in the kick panels or did you bump up the pods from 4" to 6"? Also, what's the impact between the Speaker setting and the Speaker/Tweeter setting? Especially if I have the EQ at 0. I'm still not sure how they all play together.
I do know one hard and fast rule is if changes are made that affect the signal coming out of the ACM...which changing Forscan settings does...the amp needs to be recalibrated, since the amp is getting its audio information from the ACM.
ILoveToDrive
Larry
Copake Lake, NY
I feel like my dash 4" kickers are to sharp. Will going to 300's from the 600's I have on them now calm that down?
ILoveToDrive
Larry
Copake Lake, NY
Sp/Tw Front $" Kicker Dash/Stock kickpanels (but not for long)
Sp/Tw & Sp/Tweeter/Sub in the Pods (4" Kickers)
EQ 0
I included the dictionary for convenience. This is Ragnakon's contribution...
EQ Settings - ACM 727-01-02
  • xxYY-xxxx-xxxx
    • 00 = EQ Off
    • 01 = EQ On (High-pass filter on the rear pods)
Speaker Configuration Settings - ACM 727-01-01
  • xxYx-xxxx-xxxx - Driver Front Kick Panel/Dash Speakers
    • 0 - Speaker
    • 1 - Tweeter
    • 2 - Speaker & Tweeter
    • 3 - No Speaker (ACM disable)
  • xxxY-xxxx-xxxx - Passenger Front Kick Panel/Dash Speakers
    • 3 - Speaker
    • 7 - Tweeter
    • B - Speaker & Tweeter
    • F - No Speaker
  • xxxx-Yxxx-xxxx - Passenger Rear Pod Speaker
    • 0 - Speaker
    • 1 - Tweeter
    • 3 - No Speaker
  • xxxx-xYxx-xxxx - Driver Rear Pod Speaker & Subwoofer
    • 0 - Speaker
    • 2 - Speaker & Sub
    • 4 - Tweeter
    • 6 - Tweeter & Sub
    • 8 - Speaker & Tweeter
    • A - Speaker, Tweeter, & Sub
    • C - No speaker
    • E - Sub only
Okay...did all the tweaking. Here's where it landed, and I'm pretty f--king happy.
Turned the gain adjustments on both sides back a 1/4 turn The chimes are now a reasonable volume AND the audio clarity is vastly improved. I couldn't go above 10 in volume before the tweaks without distortion. Now 15 is no problem?
I turned on the hi-pass filter on the amp. Helped a lot. You'll see which setting in the picture.
I didn't touch Forscan.
Pics of the couplers and the amp dip switches are here...you can't see the last switch...It's set for 60hz
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! IMG_4864
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! IMG_4863
Tofferf
Northern Idaho
Huge shoutouts to…
THanks so much for the detailed instructions!
redone17
Cold Spring, NY
6.5 in kicker and upgraded rear pods. Not sure about the Speaker/Tweeter setting, but, there’s no room for a tweeter. I don’t think it needs it. Plenty of hi/mid range from those Memphis. I re-ran the DSP. It’s pretty perfect for the variety of music I listen to. I could enjoy a bit more low end - but, that’s a bigger project for next winter perhaps.
