Jmschultz22
Joel
Detroit, Michigan
2017 Chevrolet Impala, 2017 Ford Explorer,
Anyone with the Key 200.4 running into limiter issues? At 20/30 volume and gains zerod out I am hitting the limiter. Any addition to the gains and it’s riding it constantly. I feel like the speakers aren’t being pushed enough, the sound is alright but not a significant improvement over stock.
I do as well. Any help on this would be awesome from anyone. I'm running all Focal and before I go a different route I too wanted to check this.
djn3400
Cleveland
Bronco BaseSquatch, Chevy Suburban, Mustang MachE
Same here. I have Polk dash and kick panel speakers.
Jaustin410
Cleveland, OH
2022 Bronco
I installed a Kicker Key 200.4 amp in my BaseSquatch today and it made a HUGE difference. It was a straight forward install that took about an hour and a half. The install was made easy because of the harness from plugnplaykits.com. There was no need to cut, splice or drill anything. As you will see in the video below, it litterally was a plug and play operation.
The Kicker Key amp has a build-in automatic DSP that fixes Ford's terrible signal as well as adding 50 watts per channel. The combination is amazing. I have a nice 3 way component speaker set waiting to install in the front and now I'm not even sure I will bother. That is just how big of improvement this is.
I have suspected that Ford is intentionally degrading the sound quality of the base system in an effort to get customers to upgrade to the B&O. These amp and more importantly the smart DSP that is integrated in it really brings the entire stereo to life. Spend you money on this before you spend it on speakers. Good speakers can't fix low power and poor signal.
I put together a quick installation video but wasn't able to show the self tuning step because I needed my phone to play the kicker pink noise DSP turning track. If you want to see that step other installation videos show you how to do that.
Edit: the harness and amp are "Kit 11". Here is the direct link to the bronco kits.
https://plugnplaykits.com/products/...y-audio-harnesses-kits?variant=41130698473662
If I were to replicate this set up, what steps would I have to take to then add a subwoofer?
KeithK
Keith
Ford Bronco
Use a different harness option. If you are using the Key Amp and want a subwoofer there are options for a separate amp and/or a powered subwoofer. Check their website.
Jaustin410
Cleveland, OH
2022 Bronco
Would this be the kit I would purchase then? I would just need to supply the kicker key amp for the speakers and an additional amp for the sub?
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! Screenshot_20220511-123257
KeithK
Keith
Ford Bronco
yes, if you just want the harnesses. FYI, it is a bit more than buying individually, but I bought both the key amp and the powered subwoofer from PNPK and it was worth it...just ran the lines and plugged in the harness. Didn't want another power amp in the trunk with the sub so got the HS8 made by Kicker...enough bass for me!
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
Fingers crossed someone releases a harness for the kicker amp and B&O systems. My new speakers are looking for more power!
PlugnPlay is working on one. There is a $700+ option out already.
I just cut the wires and used the high inputs to the Kicker Key 200.4 and 500.1.
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
Using the Key 500.1 without a harness is really easy. Cut the 4 wires into the sub and use as high power inputs into the 500.1
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
I'm running Hertz DSK 165.2 components with the Key 200.4 in bi-amp/active mode. The gains are set pretty low, but I don't run into any limits.
And dammmnnnn, does this little amp kick ass.
fitterhappier
Adam
Round Rock TX
2022 Ford Bronco
I'm not hitting limits either. Running Audiofrog GS42/JL C2-650 in front, and Infinity Reference in back (not bi-amp). Volume at 15 is extreme (but clean), and no limiter kicking in. Gains are at zero. I should add that I'm not using the plug/play kit; I had the shop wire it in old-school style with the head unit.
MannyG20
Ted
F-150
For the 4” speakers I used kicker ks series. The kick panels I used Memphis audio mjp6 which is a woofer only. I didn’t want a two way in the kick panels because I felt the highs would get lost down there. I actually thought the factory kick panel speakers were pretty good but when I decided to do the key 200.4 I figured I better replace them as well. The Memphis speakers sound great down there. Nice for the mid bass. With my 8” sub ( once I get it all hooked up) should round out the System nicely.
for the bass blockers.Crutchfield recommended the 600hz for the fronts. I bought both 600 and 300 to see what I liked best. Stuck with the 600 in the dash. When I was getting ready to do the key 200.4 I ended up throwing the 300 in the rear pods because I figured they’d be opened up more with the new amp. Agree the kicker pink noise set up everything sounds amazing. Now I just have to get my sub going right again and I should be all set. Can’t wait to hear it all working together!
Do you feel it is absolutely necessary to use bass blockers with the Kicker KS speakers? Do you use bass blockers with any brand of 4”Speakers?
MannyG20
Ted
F-150
Got my kit 11 installed today! Everything went well and was super easy. About 45 minutes to install, although I was rushing quite a bit. Sounds phenominal compared to the head unit amp. Pairs well with my JL's.
Rear speakers actually sound like real speakers now, so I'm happy.
4x JL Audio C1-400x
2x JL Audio C1-650x
I still need to calibrate, but the top is off currently, so that will have to wait.
Zip tied currently, but will come back and drill some holes once I get some hardware.
I tried the JL Audio C1-400 s but they will not fir in my right rear pod. The left one snaps on fine but the right one’s grill hits the tweeter and will not snap close.
kahunabob
Bob
Santa Clarita, CA
4runner
I have a Kit #11 with Kicker Key Amp for sale in the member marketplace if anyone is interested. Decided to go a different route with my rig. If you are in the Los Angeles area I can meet up!
cmcbronco
Illinois
2012 f-150 FX4
I think it is. If you don’t use them there’s too much bass and those 4” speakers just don’t handle it well. Muffles the highs. You should be getting most of your bass from the kick panels anyway.
TexxasBronco
Brandon
2020 GT500 and 2020 F-150
Willing to ship?
