Kicker Key 200.4 Done Correctly
AZCoyote
AZCoyote
Wiley
Phoenix
2024 Big Bend Sasquatch
Great thread.
I have previous experience with a Kicker Key200.4, in a 2022 GMC Canyon (non-Bose) running bi-amp in front with Kicker 2.75 "tweeters" and factory door speakers. I was very impressed with how it sounded. Had a harness made with unterminated wires for the tweeters which I extended as needed.
That said, can I still expect a noticeable improvement if I install a Key200.4 in my 2026 Bronco with B&O? Are you guys and gals installing it under the dash? This would make running new wires easier.
I recently installed Infinity Reference 4" speakers in the dash and was disappointed in how they sounded. I have since removed them while I pursue other affordable upgrades.
Mounted right below the steering wheel on the little panel that is so popular. Works great.
I think there are some B&O specific threads you can check first. Speakers alone usually only help and little.
Pmharris423
Preston
Roswell, GA
Ford Bronco 4Dr Badlands Non-SAS
Round two with DSP. All dip switches are down, except for the 60Hz crossover. I may add compression as I'm still getting clipping at volume 19. Again, 15 is pretty much my highest listening volume but I want to test so it all is working properly.
The systems sounds MUCH better now. The tweeters are balanced, not bright. I also have some 6.5" coaxial speakers in bigger back pods, and moved the fader so they're noticeable but not overpowering. I like.
I read online that lower clipping levels can be normal on the Bronco head unit, and that a Line Output Converter (LOC) between the head unit and the Key 200.4 can help. Maybe later.
My next steps are to figure out the subwoofer and to cut a hole in the protectors behind the Memphis kick speakers so they can move freely.
Pictures for reference:
Would you recommend the 6.5’s in the rear? I’ve been loving the bi amp setup up front but just wondered if a larger full range speaker would give some extra rear fill to the sound.
AZCoyote
AZCoyote
Wiley
Phoenix
In theory you could change the rear pod EQ to full range and those 6.5 may give more volume. But with head unit power I’m not sure it will be hugely different. I personally like just enough from the pods for fill.
Cordycord
Cord
SoCal
2016 Pilot, 2016 E300, 2005 MSM, 2001 B3500, 2010 Range Rover Sport, 2022 Pilot
I gotta say that your advice really drove my build. I installed 90% of it myself, and feel pretty good about it. That said, I've got my system set up with more of a "surround" sound rather than front-bias, and very much prefer it. The dash mid-tweeters hold their own and are very clear in this setup, and the rear 6.5" coaxial Memphis speakers do their very best to mitigate all the road noise and squeaks of the Gen6. This system can't compete with windows down at highway speeds, but is more than enough windows down around town. Windows up and it's a proper, high quality setup.
AZCoyote
AZCoyote
Wiley
Phoenix
That is awesome! It’s DOES feel good to get these things done on your own. Saved money for other mods too!!
I agree about the volume levels. Closed window I have a very high quality and loud soundstage. Windows down at 45 mph I can still jam out. Highway speeds forget about but I don’t really cruise windows down that way.
That’s how I ended up tuning mine as well. Helps to make up for the slap-in-the-face dash window reflection and relatively weak kick panel placement.
I know a lot of people who prefer front facing stereo though. I just found it harder to tune for wirh Bronco acoustics being what they are - but it can be done
P_Baff
Pierre
'12 VW GTI & '21 Ford Bronco
@AZCoyote
Have you experienced an issue where the 200.4 sounds where it isn’t pushing out the right amount of volume at your usual level on the HU dial?
Today on a song a normally listen to at 13; I had to crank it to 19.
Using Spotify on an iPhone. Maybe it was an update somewhere on the app?
Have you had that happen?
AZCoyote
AZCoyote
Wiley
Phoenix
@AZCoyote
No. I have noticed a difference between wired and Bluetooth. I always use wired now. You could double check no loose power or ground but that seems unusual.
Apple Music in particular is horrible for sound equalization across tracks
P_Baff
Pierre
I was going thru all my connections to see if something was loose or unplugged and came up with this. The black one is plugged in to the input side of the amp and the white one was tucked away. They’re both the same type of plug. Been looking for the female end of the white plug. I don’t remember leaving anything unplugged tho.
Thoughts?
Ford Bronco Kicker Key 200.4 Done Correctly IMG_1594
AZCoyote
AZCoyote
Wiley
Phoenix
Thoughts?
It’s been a minute since I’ve been under my dash to look at the connectors. So the input side is plugged in and the output side is not? When I was done, everything was plugged back in since my harness sit in between everything.
Those look like plug-and-play amp harnesses, not anything Ford OEM.
Amps usually have a speaker-level input harness, and an output harness (or sometimes terminals). Low-level inputs are usually RCA jack and/or Toslink.
Power is usually hard wired to a terminal.
Remote Turn-on is a toss-up though.
So my guess is one of those is your speaker-level input (just guessing off the size of the wire, probably the black), and one is your amped speaker output (again, just guessing off size of wire, maybe the white one).
P_Baff
Pierre
I remembered that I had purchased the Plug N Play dedicated battery power adapter, and it basically bypasses the white connector, so it stays tucked away.
All connections looked good and the system is working but not outputting like it used to. Could having the battery unplugged from the vehicle reset the HU to factory settings? I was thinking of increasing the Treble, Mids and Bass equally. Hmm...
AZCoyote
AZCoyote
Wiley
Phoenix
Do you have a link to details about this? Everything should be plugged in with all the harnesses I’ve seen.
