JKS Max Tire Kit?
Lordsandy
James
MA
Do I HAVE to remove the bumper to install this? I have the performance winch and don’t want to deal with removing the winch and bumper.
SierraBronco
Let's just say it makes it a heck of a lot easier ;)
If I tried it without removing the bumper I’d probably have to make a run to the hardware store to buy another reciprocating saw.
After destroying my current one smashing it against the floor out of frustration
Squatch
Go buy/rent an engine cherry picker and ratchet strap your bunper to it before you remove it to save your back.
It's all about the blade! Buy the really good blades... total game changer. I've used a Sawzall since I was "Only a Lad," and just discovered how much easier it is with the blades that are triple the price, haha.
SierraBronco
I’d just be bending them every time I was distracted by a butterfy while trying to keep the blade from making contact with stuff not inclined to move.
Squatch
You just need more practice handling your blade, Daniel-son. 😂
I would recommend removing the bumper too, but I'd also love to have it up on a two-post lift like in the video.
SierraBronco
Gonna start popping adderal before cutting shit
Twister22
michael
lone jack,mo
1965 Mustang 1968 Mustang Factory Five Cobra
I did the Max JKS kit a few months ago. Not bad at all.
Ford Bronco JKS Max Tire Kit? BFDEC363-2324-45A9-9A25-399630120D76
Ford Bronco JKS Max Tire Kit? 5D12D754-9D02-43FA-8987-507C27D19CB6
Ford Bronco JKS Max Tire Kit? 9B370BCD-5A1D-4BD8-89F0-4C397008D330
Ford Bronco JKS Max Tire Kit? D0F8339B-69D3-442D-8B54-4B7A76BBFA1E
Ford Bronco JKS Max Tire Kit? 48BDE4DF-20CD-4F90-B7AD-5A4FEFC9C7BB
Ford Bronco JKS Max Tire Kit? CE528985-BD8D-4A3B-94FD-D2930A366DD6
Lordsandy
James
MA
One other quick question for those who have done this, what is the best option for a mudflap with this kit installed?
broadicustomworks
Hanging Rock, North Carolina
lol I didn’t remove mine. I’m lazy I will always try the easy path first. Which sometimes is a lot of work.
Same.
Just be prepared for a forearm and shoulder workout for leverage, having a couple of blades go banana shaped on you, and having an extra joint somewhere in the middle of your forearm would have been handy.
A lot of it depends on your level of "want to".
It's either more work to saw or more work to remove the bumper.
With mine I would have had to remove the winch, winch mount, and bumper. After installing it all alone the first time, I didn't want that smoke again.
So I chose violence that day and made it work.
In retrospect I should have removed the bumper and installed the LOD frame reinforcement at the same time.
cgv
Apex, NC
Bronco Badsquatch, Explorer ST
For those that installed the kit, how much shorter are the metal brackets for the rear side of the fender liner compared to the OEM plastic piece? Trying to figure out how much clearance is gained.
Also, does anyone have a part number off of that plastic piece they removed ?
