Rear spare tire delete kit - recommendations?
CassMaxwell
Cassandra
Callicoon, NY
2024 Ford Bronco Wildtrak
Hello! I'm sure many of you had a spare tire delete kit done. Any recommendations?
Mikem1025
San Antonio
2023 Bronco
I'm not sure if understand deleting tires, but to each their own I guess.
Mikem1025
San Antonio
2023 Bronco
Then a rock you try to make roll?
Valhalla
Valhalla
Chattanooga Tn
I run good tires, have a plug kit, and a compressor. Off highway I run an E rated tire on a Rock monster wheel. I think I'll save the weight out back, as you say though, to each their own.
Mikem1025
San Antonio
2023 Bronco
Fair enough, I like a little junk in the trunk.
Valhalla
Valhalla
Chattanooga Tn
Mikem1025
San Antonio
2023 Bronco
I was going to go that route, but decided to tuck it behind my spare. Used the AGS tire gate w/ the reinforcement.
SierraBronco
Ran with a fullsize 40” beadlocked spare for awhile. Plug and patch kits are pretty effective and with beadlocks (and patience/luck) you might be able to patch from the inside if needed. Got an air compressor and air storage so now that the spare is getting deleted the compressor will stop working and patch kits won’t work.
Disirregardless-I didn’t like seeing how much the frame was deflecting even with the mount reaching halfway onto the crossmember. I bought a delete kit from @Turn Offroad
