Spare Rear Tire Delete
mdavismac
Martin
Goodfield, Illinois
2024 Bronco Heritage 2-Door
I went with this one manufactured by Fab Fours. Very happy with it and it is made in the USA.
Looks great! Does the steel sit directly on the tailgate when you install? And do all four of the rubber corners sit flush against the tailgate?
Thanks and nice work!
KenV
Ken
Las Vegas
2023 Ford Bronco
The steel tire delete is mounted directly to the tailgate using original hardware. Provided are four rubber pieces to be placed on the four outer edges of the tire delete to protect the paint. However, I located and installed four plastic round washers (.125" thick) when installing to separate the tire delete from the tailgate. I also did not use the four provided rubber protectors since there was a gap between the outer edges and the paint of the tailgate.
