IPMA Cover Removal
Xinnes88X
Furnace Creek
Kia
I looked in the fourms and did not see anything on this. I want to remove the IPMA Cover above/behind my rearview mirror to run some wires underneath. Has anyone done this before? Should it just snap right off with a trim tool? TYIA
flip
Phil
IN
www.ruxerparts.com
Fords
Image Processing Module A (IPMA)
Special Tool(s) / General Equipment
Interior Trim Remover
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. Using the interior trim remover release the tabs and remove the IPMA cover.
    Use the General Equipment: Interior Trim Remover
  1. Disconnect the electrical connector.
  1. Remove the IPMA .
    1. Remove the upper tabs.
    1. Remove the lower tabs.
Installation
  1. Install the IPMA .
    1. Install the lower tabs.
    1. Install the upper tabs.
  1. To install, reverse the removal procedure.
  1. NOTE: This step is only necessary when installing a new component.
    • If a new IPMA has been installed, using a diagnostic scan tool, complete the PMI process for the IPMA following the on-screen instructions.
    • If a new IPMA has been installed, carry out the camera alignment using a scan tool.
Make sure the cable/harness in there get back in their clips correctly, otherwise they rattle like crazy and it sounds like it’s coming from the rear cargo area.
murrman
Sean
Toledo, OH
2024 2 Door Black Diamond
For anyone who has removed this cover, where did you start prying? I’ve been trying for the past few minutes, and can’t get it off. Should I start at the bottom or the sides?
Ducati1098
I always go from the side. It just pops off pretty easily
