HOSS 3.0 Lift options?
Drose017
Dennis
New Jereey
2023 Bronco 4Dr Wildtrak
Niiiiice. What size tire did you go with? Any rubbing? How do you like the UCAs? Did the alignment tech have any feedback about them or if they made a significant difference?
I went with 37” KM3s. No rubbing although I haven’t tried cranking it all the way but on a k turn no issues. The install guys didn’t say much other than they recommend due to the new angles. I am liking the slightly stiffer ride better than stock so far. First offroad Is 5/20 so we will see.
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
For those that have installed the RPG collars.... The Fox springs are supposed to be progressive, so how does the setup do with squatting when you add some weight in the rear?
NJNMDoc
Southwest
Bronco Wildtrak
Can’t say- I haven’t had a ton of weight in it. And I don’t plan on using this rig for overlanding purposes (2500 for that) so it’s not really going to have to carry a ton of weight. That’s a good point tho curious if anyone can comment.
ronnyek
San Luis Obispo Area, CA
2023 Bronco Wildtrak, 2018 Mustang PP2
how bad do the collars or the lift stress cv axles etc? Is there a differential drop in the 2.5" lift?
Geronimo
Wisconsin
Tacoma, Bronco Badlands Sad on order!
There is a diff drop in RC 2 1/2" lift. Not sure how much drop. There is obviously going to be some additional angle to the CV shafts. Most people say 2 1/2" or less shouldn't be a big deal. Will they wear a bit sooner than if left stock? Probably so. At some point down the road if we keep them long enough, we have them replaced. In the mean time, we enjoy the look and ride.😎
NJNMDoc
Southwest
Bronco Wildtrak
No this is inaccurate. There is no diff drop with the collars bc they do not alter the suspension geometry in the same manner that a spacer lift would. If you do some research you can read about it. If you don’t want to do that call the guys at RPG and have them talk you through it.
Bryced15
Tennessee
Mustang
No clue. I didn’t receive those.
Talked to RPG and they said the bolts and cable clamps are for the live valve wires on the hoss 4.0. They accidentally sent them with my hoss 3.0 kit.
NJNMDoc
Southwest
Bronco Wildtrak
Ahh… makes sense.
Dino171
Dean
New Hampshire
3 BMWs
All this info is super helpful. Two clarifying questions for those that have the RPG collars...
1. Are you noticing any reduction in the squatting when braking or initial side to side turn-in lean when cornering?
2. The install shop that is well know in my area for working on/customizing Jeeps & Broncos stated I should also get the RPG Upper Control Arms at the same time as I may have difficulty with alignment and tracking - may be more skittish when driving without them.
Love to hear your thoughts.
Thank you
NJNMDoc
Southwest
Bronco Wildtrak
Thank you
1) Nope, handling dynamics are improved actually with LESS squatting in both braking and cornering.
2) I did not change UCAs, still on stock. No issues with alignment or driving. The only comment my alignment shop had was that they would have liked an adjustable panhard bar. I instead just ordered the RocKJock relocation bracket for $100. I still may consider doing the UCAs in the future, but I'm not (personally) sold on the RPG ones (might be the way to go but I'm not 100%) and I need to do more research. I'll say this much- for right now replacing the UCAs is pretty low on my list relative to dealing with the shitty stereo if that gives you any idea of how much of a non-issue the UCAs have been. Tracks great.
Dino171
Dean
New Hampshire
3 BMWs
Great feedback. Thank you!
meffie
Raven
'23 WildTrak
Is the rockjock relo bracket a must have? As much digging as I have done, this is the first time I've ever heard someone mention it.
I noticed on their site they also have an adjustable panhard which seems much less expensive than the others out there
NJNMDoc
Southwest
Bronco Wildtrak
Nah- I don't think it's a 'must have'- I haven't had it for about 6 weeks. Hell I still don't have it. It's fine w/o but I think this will help improve driving dynamics more. Possibly track a little better on road surfaces with high crowns etc... Not urgent. But for 100$ I figured what the hell... I'll be reporting back on that too. Reality is that would be a decent mod for ANY lifted bronco. Beat $8-900 for an adjustable as well.
meffie
Raven
'23 WildTrak
I certainly agree. Just really surprised I haven't heard anything about it.
