Hood open alert -- false alarm
Denver-Dan
Ford Bronco
Hi all,
I'm seeing multiple posts about this, but my 2023 Bronco is having an issue where the hood sensor is triggering a "hood open" alert incorrectly. This triggers the alarm when parking, and a "hood open" warning on the dash when driving. It's increasing in frequency lately, and doesn't seem to be linked to any particular driving or environmental/weather condition.
Has anyone had any luck dealing with this, or getting help from Ford? I brought my car into a dealer a while ago, but they couldn't replicate the problem and sent me on my way.
Thanks,
Dan
Ducati1098
There's an SSM which is more than likely posted on one of the 20 different threads about it. Very common issue and repair.
Ford Bronco Hood open alert -- false alarm 1743093538410-nd
JT58Bronc
JT
Fl
Is this something the dealer has to do or is it an easy fix I could do? Mine has done this a couple of times and it seems I have to slam the hood for it not to trigger. I'm reluctant to bring it in for this as it is not consistent and can't be easily demonstrated.
Denver-Dan
Ford Bronco
I appreciate you linking this. I'd found this prior to my last visit to the dealer, told them about it, and they didn't seem to know what to do with it. Do I need to try another dealer?
userdude
Denton, TX
2023 2dr Badsquatch
If "Replace the hood latch ... part number ..." produces blank stares at your dealer, either talk to someone else or find another dealer service.
Ducati1098
Yeah I mean It's a known problem, they should've just replaced the hood latch. If they wont, I would definitely just bring it to a different dealership.
AlaskaMatt
AK
2022 Bronco Badlands Sasquatch 2D
If this hood latch assembly can’t make it 4 years then I’m not replacing it with another one. It was a PITA, but i unbolted the latch, oriented it to rip wires separately from the micro switch with needle nose pliers, popped the white retainer holding it to the bracket left of the latch, pulled it back through an opening to the left, shorted the wires using a butt splice, and left the connector and wire under the plastic trim so I can get to it later if needed. Iā€˜m not going through this twice. Seems like a dumb design.
SlowTrak
NorCal
It's an SUV btw....
Most dealers are "if we can't replicate it, we will tell you to pound sand".
The hard part is replicating something that is intermittent....
CalvinT
Calvin
Phoenix, AZ
The only way to do that is keep a log. I had an intermittant problem with my driver door lock. I started tracking temperature, time it had to sit before failing, when it worked right and when it didn't. Took the dealer about 15 minutes to find the problem once I gave them a recipe to create it. The problem only happened between 80 and 95 degrees (roughly), after Bronco had set for at least 15 minutes and it wasn't in the shade. Park it in the shade or higher or lower temperatures and the lock worked perfectly.
You need to do something similar for your open hood alert.
