Hood Deflector really work?
JimmyZ
Dawsonville, Ga. 30534
Bronco 2023
Iceman62
Tim
Omaha, NE
2024 Bronco / Sasquatch
Taltyman
Paul
Forney tx
Jeep wrangler Rubicon, Ford F350, Braptor
Trying to prevent my windshield from getting cracked. Had to replace the one in my Wrangler 4 times in 5 years. Do these Bronco Aeroskin II Black Textured Trail-Armor Hood Deflector really work for that? Also has anyone painted theirs to match the hood color?
https://www.ford.com/product/hood-protector-trailarmor-aeroskin-ii-black-textured-p2918445229
Same issue with our Jeep and already have 2 cracks in our Braptor at 15 months. Ours also had a window film installed. That didn't seem to help. They only list Bronco as an option so not sure it would even fit a Braptor. At $89 it may be worth a try.
tomfoolery
Thomas
ATX
MY24 2-Door Big Bend Sasquatch in Eruption Green
I could be mistaken here, but I’m pretty certain those are only intended to protect the leading edge of your hood from rock chips in the paint, nothing to do with your windshield.
KillerPenz
North East
That's about all they do, and decrease the amount of bug guts on the windshield. Which with the way my hood was looking, makes this well worth it.
I still catch rocks even though I have the hood protector.
Dreamer
Kevin
Connecticut
Ford Mustang GT convertible
I believe the hood deflector also creates a little different wind patterns/turbulence while driving.
Had nothing on my bronco for a while and receive several small chips lowdown on the windshield
Since installing the deflector, the only chips I’ve received are much higher up on the window
Definitely reduce the number of bug splats too
from what I can see, I would say it works. The only downside is that the washer fluid goes everywhere if you try to use it at highway speeds. Very little hits the window anymore.
OtisFE
Otis
Palm Coast FL
2022 Bronco OBX
It certainly helps but it’s not a 100% guarantee
After getting a bunch of pits in the first few months I got one. Two weeks later got my first crack ><
But in the months since then only 1 more minor pit, and I do a lot of dirt and gravel road driving - so it definitely helps
SkyKing
Boston, MA
'21 CG Wildtrak, E.R.A. Cobra 427 S/C
It will protect the leading edge of the the hood where it covers it. There is simply no way that the small change in the wind pattern on your hood would somehow change the direction of a rock! There is a reason they just call them "hood" deflectors, and there are no supporting wind tunnel tests that are marketed to show the wind altering the path of rocks or bugs. If you think you have fewer rock chips on your windshield because of this, you must have missed high school physics.
PWillette
Parrie
Maine
Not 100% guaranteed but in three years over highways, city and logging roads mine has worked great deflecting debris and bugs.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I went on long trips both before and after getting this same hood deflector, and I can tell you, I get a lot less bugs on the bottom 60% of the windshield. I think that's a hint. It isn't 100% effective, as others have said, but it does help. Making the affected part of the window smaller is only going to help, even if you might still get a rock chip (I got one on the passenger side about a year after putting it on).
OffRoadUSA.com
Andrea
Central TX
offroadusa.com
2023 Bronco
Hood deflectors definitely can help with bug splatter and minor debris/rock chips. Overall, they’re a solid option for some extra protection but not a guarantee that you'll avoid windchips chips or racks
Headsong
I have both these AND Exoshield-like covering. The AeroII's will bump some stuff over the windshiled, but not all. I have a lot of pits from hits in the plastic, so for sure they don't do as I'd hoped. But the plastic coating does! 35k mi, no cracks.
