Bug shield hood deflector.
Lak34ers
Troy
Seattle
Just a POG to off roading. Minimal mods made. Curious about the bug shield for hood protection. Guy at the dealer mentioned that it has scratch his hood. Pain to remove. Not functional just looks good. Any comments, suggestions appreciated. I know Beauty is in the eye of the beholder.
Got the gloss black from IAG. Super happy with it. Cuts way down on bugs and no windshield chips yet. Got one first week of ownership before installed. Most can't even tell I have it blends right in with Black Bronco. If you have a gloss black grill might look really good.
Ford Bronco Bug shield hood deflector. 20230706_144609
sportcoupe
Georgia
2023 Bronco
Yes it protects the front of the hood from chips. That's pretty obvious.
The primary purpose is to deflect small rocks and bugs from hitting the windshield. It does that very well.
Jazer
Jessica
2.7 OBX
How would you rate the finish? I contemplated putting one on, but I am still not sold on the look. I also really wondered if the gloss black finish would last.
HeliPilot
Kenny
CT
2022 2.7L SAS
Mine was installed at dealership prior to purchase. I can’t swear to effectiveness, but I can say that after 15,000 miles, I still have my windshield.
Jeepbuster1!
Bernard Kubat
7402 South 70th Street
2022 Bronco
I've found that before you add anything that has the 2 sided tape to prep where it is going to stick to your hood with 3m adhesion promoter.
williamshafer
William Shafer
New Palestine, Indiana
Jeep Rubicon
Drove without it for a couple weeks before install. Definitely reduced bug splatter on windshield but doesn't eliminate it. If you drive at night in the summertime you'll have bugs. I've used on two different Broncos for year and a half without a single rock chip. As a note, I work near a quarry and drive behind rock haulers all the time.
BruceEnglish
Bruce
23 Wildtrak
I installed on both my BRaptor and Wildtrak. I did apply PPF to the area from underground graphics before placing it down. The adhesive seems to stick a bit better to the PPF and if I ever wanted to remove it would be easy peasy.
As far as the effectiveness... It DOES cut down on the bugs that make it to the windshield. I cant say much about rocks but my windshield is still in tact.
One thing I noticed is that with my top off passengers in the back seat dont get blasted by as much air. I have had numerous passengers tell me this including the kiddos.
Interesting about the air in the backseat, I've had mine on for a few weeks now and before I put it on I could wear a hat no problem, now I can't, blows right off. This definitely indicates the deflector modified the air flow. Now I can't decide if I would rather be able to wear a hat or protect my windshield....
Packen8
Jerry
Maine
Ram 1500
I bought the old school screw on one for full edge and width protection. Took 3 months to get 🫤
I didnt want the adhesive style as I didnt want any chance of it flying off if I didnt clean or adhere it properly. It could look better, and the fender corners have a gap for some reason, but removal will be easy and no cleanup.
And I found it on some shady website that had it on sale with a coupon. Total was $28
😳🤣 so I cant complain that it took 3 months. AVS Bugflector II
Lak34ers
Troy
Seattle
Very good finish. No scratches. And sticks on solid.
Ed Morris
Ed
Longmont, CO
Jeep Grand Cherokee
I have one, as I figured it was worth it just to protect the leading edge of the hood from rock chips. I don't think it does much for bug splatter when driving at highway speed, though. I still get TONS of that, noticeably more than on any other vehicle I've ever owned. I suppose it MIGHT keep some of the smaller bugs from hitting the windshield, but it definitely doesn't keep the bigger ones from doing so, and they're the ones that make the most mess.
BigHoof
PA
Ram 2500
The one sold by Ford comes with the adhesion promoter.
Bobk
Bob
Hammonton NJ
71 Maverick, 84 Mustang GT350, Ridgeline
AK007
Washington DC
Awaiting my Bronco
The first one I put on flew off going 80 in some high winds because I forgot to tell the ppf and ceramic coating company to install until the end, the 2nd one worked much better. I used gorilla adhesive tape, and used clamps with the hood slightly open for 24hrs to help with adhesion. Definitely a good idea to have ppf under it. My only gripe is the water that pools on the corners. Otherwise it cuts down on bugs and rocks and I love how it blends the WT gloss black grille with the gloss black deflector against the white hood.
Ford Bronco Bug shield hood deflector. IMG_1950
Ford Bronco Bug shield hood deflector. IMG_1947
Ford Bronco Bug shield hood deflector. IMG_1943
