Hood ajar notification while driving down the road?
Thingfish
Jon
North East
2023 Badlands Area 51 High pkg - no Squatch
Forgive me if this is obvious, but I can’t figure it out: How do we send a “private message”?
if you click on their profile name you will see a link at the bottom to “Start Conversation”. This will be a private message thread for the two of you.
AnimalTheBoxer
CA
Ford rep was super responsive here and created a case number for me. I sent the same to the dealer when i made the service appt. When i showed up they hadn’t looked at the case number :( A couple hrs later i get a call that the tech diagnosed the hood latch must be faulty but the part is backordered for 3 wks.
BroncoPVC
Paul
Seattle
2021 Bronco Badlands,Sas, 4dr, Soft Top, Rapid Red
I also am experiencing this issue but mine came on a couple days ago and hasn't turned off.
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
Y’all come on here and don’t read anything. Just post away.
lower your hood stops slightly and you should be good. .
Bugkillah
Keith
North Augusta, SC
Base Sas, Badlands, Wrangler, Nissan Frontier
I agree, I read the first page or so, then skip to the last. OP should update his first post with the fix…
spiG
23 BD/20 Ram 1500
Tried that has gone off 2x since doing it
Lifeliberty
Moonbeam👀
Columbus, OH
The hood adjust will only work in some cases. It depends what the issue is. Has anyone identified where the actual sensor is?
Is there a way to disable this all together?
It seems Ford's "fix" is just replacing parts. I'd like to know how to actually fix it or disable it. Maybe by pulling a fuse or complete the circuit by connecting the wires and bypassing the sensor. I don't need to know if my hood is up from a computer, I can see if it is
rainbronco
NVa
Chevy ZR2
Happening to me too. Of course it's a week until I can get into the Ford Dealer. So hope my alarm doesn't go off at 3am again.
spiG
23 BD/20 Ram 1500
Had my third alarm yesterday, plan on taking it in just don't know when, sent Ford a PM hoping they can at least expediate the replacement of the latch.
p18303
Stan
Chicago
2022 Ford Bronco
Had my latch replaced, and now have no problems. Took a bit over a week to get the part in. In the meantime the dealer disabled the hood ajar alarm so it wouldn’t keep going off until the part came in.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello! I can look into this for you on my end. Could you please send over a DM with your VIN and Ford dealer info?
p18303
Stan
Chicago
2022 Ford Bronco
I have no idea how, but the dealer disabled the alarm from the hood sensor so the car alarm wouldn’t keep going off at random hours. After the new hood latch came in and got installed they activated the hood alarm again.
Jumpmasterken
Dutch
FT Bragg, NC
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Hi, I'm having the same issue. It happened twice yesterday and once today. I also own a Bronco Badlands that I took delivery on last November. The first two times I stopped and checked the hood and it was completely shut, but I opened it and shut it again, however the warning message came back on again a short time later. The only way I could get it to clear was by turning the vehicle off and starting it up again.
