High Temps Warning, Boosted
B22-2023
B22-2023
Houston
I think the Fox 2.5, Ride or King's shocks. all of which have remote reservoirs, would be cheaper and every bit as good, especially if you spring for their tuning mods. Besides the winch and front bumper what else are you running that has put on that much more weight?
Grear suggestions here, after research I'm going for the Fox 2.5s in the rear, see how that goes. Not up to the premium called for by Accutune etc. (yet), and it's an easy install for me. It's hard to figure on where to but, these shock web sites are all over the place on price and "fitment". Any suggestions?
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
I would go for Accutune and their upgrade on the rear shock, as most of the cost of the upgrade is replacing the spring from a 185# to a 250# spring. It can be purchased separately, but as much as your truck weighs, you might need something heavier. The 185# will not be heavy enough for your truck.
https://accutuneoffroad.com/product/21-bronco-4-door-eibach-rear-spring-kit-for-fox-2-5-pes/
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
I was about to say something smart aleck like, “I thought people in Vermont were tight, but…….“.
On the other hand, I drove past a scrap yard on my way to the CAT scales today and wish I thought of this first!
Cheap Yankee pro tips lol
B22-2023
B22-2023
Houston
Great idea, thanks. Meantime headed in to have some rear pinion bearing noise looked into…..
seananigans
Sean
Jersey City
2022 Ford Bronco Wildtrak 2.7l
Feel like the intercooler gets no air with the pic of that bumper. But I guess if it’s high oil temp, then that’s more radiator related? I’ve had overheating while datalogging but that was in the engine
B22-2023
B22-2023
Houston
Sorry, I need to take a better pic. There is air to the intercooler, and at 85 mph into a 30-40 mph head wind - this is West Texas we are talking about - there is plenty of air In and low back pressure underneath to release it. My inclination anyway is the radiator, as you mentioned and and @GreyZ did, particularly that the incoming air is finding a path of less resistance around It.
The truck is at the dealer through the weekend, so I will dig into that process next week. Easy fix, plus throw my cooler thermostat* in, and see how it goes.
* comments were made re cooler thermostat, and I want to clarify that the weight of this thing notwithstanding, if I can head off those temp spike at load by starting at a lower temp, it’s a win. And for everyday hard driving, I’m curious to see if this boosted engine performs even better, while watching what MPG does and noting that low speed power may be affected. As I have said, these TT Ecoboost engines are not like anything I’m familiar with and have surpising reactions to mods, some good some bad.
CatMonkey
Lafayette LA
This is just another thought due to your weight issue, but with larger and likely higher weight ratings on your tires, have you experimented with air pressure to see if some of the high loads issues could be attributed to rolling resistance?
B22-2023
B22-2023
Houston
Good question - loaded, I run 45 psi all around on the highway and it’s plenty. Chalk tested it to be sure.
CatMonkey
Lafayette LA
But have you checked it fully loaded with passengers and gear? Another 1,000 lbs of weight, or more, would likely make a difference to the contact patch. Just spitballing.
B22-2023
B22-2023
Houston
You are spot on - I checked all loaded before the trip. Aired back up to that level on the way home.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Why not ask Buckle Up Buttercup?
She had a bad gas milage issue which was solved with the removal of her aftermarket bumper, which closed off the bumper opening just like your bumper?
MWILD
Central North Carolina
2021 Base/2DR/2.3/MT & 2023 Model S Plaid
Just curious how does yours sound and does it make a noise at various speeds? I’m hearing a high pitch roaring noise at 45 up to 55mph and then it goes away. I’m thinking my rear pinion bearing is toast.
James Cole
MX
Badlands Sasquatch (hopefully)
Have you blocked the lower radiator shroud as suggested by @GreyZ ?
I swapped my intercooler as well but did block that part with a piece of polycarbonate as it didnt seem right to leave it open…
In oem config air still bypass the radiator but less so than fully open with aftermarket IC.
GreyZ
Gulf South Louisiana
It seems that not all 2.7s have the same radiator shroud it would be interested to see an photo of OPs from the underside.
