Hi-Lift Jack mount location?
BroncoKong Jr.
Andrew
Felix808
SRV CA
NightTerror
Mass
Bronco Wiltrak
Heres my setup.
Clears top and speakers and is inside so less likely to get it stolen.
Utilitizes the factory holes in roll bar.
Anyone else not have these holes in thier roll cage? Starting to think about mounting it to the bolts for the roof across the back seat.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Heres my setup.
Well done! Are you still running this set up? Does the Jack mechanism rattle drive you crazy? Cheers.
Dingo
Charlie
FLorida
2022 badlands squatch Bronco
Heres my setup.
Is this a 48 or a 60 inch and what hardware did you use I'm looking for a like solution to the jack storage.
Also awesome setup!!!
Havoc1
07 F250, 20 Accord Sport, 21 HD
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Well this is interesting, I was gearing up to try out this mounting solution and the holes in my 23’ 2Door (rear roll cage near the speakers) are not threaded. Why would they be there if they’re not threaded?
(Edit: Unless you guys tapped them?)
Ford Bronco Hi-Lift Jack mount location? IMG_0711
thatspecialbeat
Ryan
Meridian ID
Subies
My 2 door is the same. That is where the seatbelt attaches and they are not threaded. We do have threaded inserts on the sides of roll cage that would work if the top was off. I don't know if 4 doors have those.
lni
Lni
Seattle
2Dr Badsquatch, Porsche GT4, BMW M3
Looking at the pictures, there is evidence of tapping the hole in shavings just underneath each mounting point. It would be a M10 1.5 pitch tap, and you'd need a right angle attachment, unless you want to remove the top to tap the hole (assuming the jack fits with the hardtop installed).
Jack is the 48" model, which I have. 60" Model is far too wide to fit in there.
I'm going to try this, this afternoon, but I'm concerned that the hardtop might interfere removal/mounting. If BigMeatsBronco sees this, please let us know if the hardtop fits to mount/dismount the jack.
I got a cheap Chinese one on Amazon and re-drilled the holes for my Turn carrier. It's not as nice as Orions (that one is awesome), but it sits a bit more center line.
Ford Bronco Hi-Lift Jack mount location? jack1
Ford Bronco Hi-Lift Jack mount location? jack2
Ford Bronco Hi-Lift Jack mount location? jack3
