Help! My gf put antifreeze as windshield fluid
Status
Not open for further replies.
nickyp1020
nick
chicago
2022 Ford Bronco
So i got my 4d badlands about 3 months ago. up to now no one has driven it other than me. I came home from a BAD day at work and needed to run errends. my girlfriend said that she would do them for me if she could drive my truck (somthing shes been begging to do) i was so tired so i just threw her the keys, in disbalef she comes back and had the following conversation with me.
"i topped you off with the green windshield stuff cuz you were low"
what green windshield stuff? whindshield wiper fluid?"
yes"
"green? not purple or blue?
"yeah the green anti freeze stuff from the gas station"
"babe.... show me the fucking bottle"
turns out, its anti freeze. she put ANTI FREEZE IN MY F&&&&&& WINDSHILD WIPER TANK. SO this leaves me wondering, how do i fix this? can i fix this or do i just kill her?
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
First, don’t use the windshield washer. Tape it in the off position.
You or your dealer can access the windshield washer bottle from inside the front passenger fender well by removing the fender liner. It’s pretty easy. Just 4 metal bolts and about 12 trim panel connectors.
EDIT1: Posted at the same time as @flip. Follow his recommendations.
EDIT2: Removal and installation procedures from the Workshop Manual are attached below in a follow-up post.
FormerJeepJunkie
2019 Rav4
I don’t have a walkthrough, but you basically remove the washer tank and drain it. It’s really not that big of a deal. I wouldn’t run it with coolant in the tank (not 100% sure if you’ll have a chemical reaction with the two)- but I don’t foresee an issue with just draining it, filling and running it through the pump to clean out the lines. Thank her for her effort to make you happy- trust me.
Much better than adding it to the oil or gas 😎
broadicustomworks
Hanging Rock, North Carolina
SO many reaction emojis would work here.
Take the tube/hose off of the washer fluid reservoir, drain it.
Rinse, repeat.
A bit of alcohol after a few cycles, then rinse again and repeat with clean water.
Add washer fluid and continue on living with the non-deceased GF.
And take this as an opportunity to teach a few basic car maint items to her, as she apparently has not had much in the way of self-reliance lessons on basic vehicle upkeep.
Remember in the end she was trying to do the right thing, and it's a minor detail and a bump in the road here.
It's not like she put it in the oil or put diesel in the tank...
Roger123
Roger
VA Beach, VA
Pull the discharge "squirter" hose from under the hood (I don't have my Bronco here but I'm assuming there's a hose that attaches to the "squirter"), run into a bucket, push the button to run out the fluid, re-fill with WWF, have her make you a nice dinner and call it a day.
15Min fix at most with no damage or bad things done.
‘21OBX
90Bronco19
2022 bronco outer banks
Lol way better outcome than putting washer fluid in the coolant tank or engine oil fill. Drain rinse repeat. Go buy flowers take her to dinner apologize if you lost it and laugh about it for years to come.
d_bearhugs
Dani
New Jersey
2022 Base Bronco 2.7L
I am very very curious how she didn't know what antifreeze was used for. Kind of get how she could read antifreeze and think oh it stops things from freezing but idk I have known since I got a car at 17 that antifreeze was for the engine and wiper fluid was for the wipers.
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
Drain. Run some dawn through it a couple times then refill and u should be good to go. The dawn will scrub the lines too.
broadicustomworks
To be fair a casual, non-knowing person could be confused.
AF is no longer just green.
WF is no longer just blue.
DexCool and the orange "Antifreeze" washer fluid are close enough in color (and Prestone makes a version of both, pictured below) I can see someone who didn't take the time to check or felt anxious being out of their element making a simple mistake.
Ford Bronco Help! My gf put antifreeze as windshield fluid 1658932842140
Ford Bronco Help! My gf put antifreeze as windshield fluid 1658932932198
shieldsy
'79 Bronco XLT
My daughter put a full tank of diesel in my gasoline engine. You would have thought the nozzle size difference would have clued her in.
The first of many times I was forced to do a paternity test. Just to make sure we were really related.
Scopebit
Troy
Tricities, Washington
Status
