- First Name
- John
- Joined
- Mar 16, 2023
- Threads
- 30
- Messages
- 1,408
- Reaction score
- 2,499
- Location
- New Jersey
- Vehicle(s)
- 2023 Ford Bronco
- Your Bronco Model
- Wildtrak
This
No passive entry for the locks or push button Start. Which after unpacking and repacking a car full of luggage every couple days was noticeably a bit annoying putting down arms full of stuff to pull out the key and unlock the vehicle.
no rear window lockouts for kids.
Passive entry / pushbutton startthere were a couple times where I was reversing out of a spot and the car slammed itself in park.
All of the strangeness that comes with a first gen foreign off roader.
There were just too many examples of these oddities when the vehicle was doing as it was designed and I kept thinking what happens when things actually go wrong…especially considering the service situation.
It’s a fob with a switchblade style key. Lock/unlock/alarm buttons on the fob. No passive/proximity entry so it doesn’t detect you. Hit the unlock button, flip out the key and use a keyed ignition. Basic stuff.Passive entry / pushbutton start
- is there a physical key to lock/unlock doors, or a fob requiring a button press?
- is there a keyed ignition?
I'm all for a standard physical key (that isn't a blade inside a fob) and zero passive entry or pushbutton start if it's the former, but require passive entry if it's the latter (like the Bronco's fob).
Automatically going into park while reversing
- give me a manual transmission or give me death
Reverse camera quality
- solved by keeping it analog
Rear window locks
- make a 2 door option and problem solved!
I dig the Grenadier (and Quartermaster) but I can't get behind the four door dimensions/look and the auto BMW gearbox. The oil change light and some other quirks are frustrating but aren't a huge issue until you consider the price point. All in, I couldn't see myself in one without stumbling upon a crazy deal.
I also think they look fantastic and no doubt would be capable off-road. But for 80k plus, there's way too many sacrafice, bugs and engineering issues for me. Add to that the BMW mechanicals and some electronics and I'll definitely pass. And I'm not bagging on the refinment and driving, I have a 44 Excursion and Bronco so I'm used to unrefined driving dynamics. But the other issues and the expensive to repair BMW bits would send me to the Lexus dealer for a GX Overtrail.The Grenadier slightly piqued my interest so I rented one on a family trip and put on 1,000 miles. Flew into SFO, so had it in San Fran, Yosemite and Monterrey/Big Sur.
Thought I would share some thoughts. I didn’t take it off road unfortunately but this is more around everyday use -
I liked it, not as much as I thought I would. If it were strictly driven by me and me alone that’s one thing, but it was pretty flawed/compromised for everyday driving / family passengers. The steering and turning radius is lacking for around town driving. I think this has been improved slightly for the 2026, mine was a 2025.
The steering doesn’t really snap back to center and takes a bit getting used to. You need to manually turn back to center when coming out of turns. It feels weighty which is nice but there’s a lot of input needed. I got used to it but my wife pretty much hated the feel of it.
The turning radius is probably one of the worst of a recently manufactured vehicle for this size, and is the primary common complaint. Lots of corrections are needed around a parking lot. Especially tight lots - Turning into spaces flanked by occupied spots usually required a 3 point turn which is a bit crazy. Or for example, pulling out of a parking lot aisle with someone passing, you would need to completely stop and wait to have enough room to turn. There were a few awkward moments of others seeing you stop, then they stop and wave you on, and you roll down your window to explain that they need to move or reverse because your unable to make the turn without hitting them. They just don’t expect you to have the turning radius of a semi truck when you’re in a defender looking suv.
in general I would say just…finicky…My wife and kids were successful about 50% of the time to fully close the doors. And sometimes the car would throw itself into park when reversing out of a spot, to the point you think you hit something, but it was really because a door wasn’t 100% shut with a thud. It could have also been provoked by seatbelts not being buckled but I doubt it - pretty sure it was the doors. This happened a bunch.
constant rear rattle. Seemingly the tailgate or ladder.
No passive entry for the locks or push button Start. Which after unpacking and repacking a car full of luggage every couple days was noticeably a bit annoying putting down arms full of stuff to pull out the key and unlock the vehicle. One of those features you get accustomed to with modern cars that becomes obvious when it’s not there. The sticker on mine was 83k BTW.
no rear window lockouts for kids. Probably no big deal for most, but dealing with a toddler in the backseat constantly not listening and messing with the windows got old quick. Seems trivial, but when driving around the Big Sur wildfires, and trying to keep out the smoke it actually was an issue - pulling over multiple times arguing etc, for something that could so simply be resolved with a feature every other vehicle has. Or my toddler opening up the window while exiting the car (happened often given the allure, since we’ve always had the lockout feature) then you walk around, take out the key (since it doesn’t have keyless) turn back on the car and roll up the window. You forgive these things because it’s a pretty cool truck, but also think why am I dealing with this in 2026 on a 83k vehicle. It’s not even an option. And they figured this tech out 30 yrs ago.
some technical issues. Like an off road mode flashing error on the screen that stayed on for a couple hours.
Everything else (minus the price) was to the positive. Huge cargo, very nice seats. I loved every second of the airplane cockpit and safari windows. If it I wasn’t using it for family use I probably would have enjoyed it more. Also I think the 2026 improved the turning radius some (5%), and the steering feel a bit.
edit - looking into it further - here are the things missing (I don’t think these are options but I could be wrong) but my $83k spec fieldmaster did NOT have: power front seats (obviously no memory), rear heated seats, adaptive cruise, blind spot monitoring (obviously no lane keep assist), passive entry locks, push button start (obviously no remote start), child rear window locks. Etc. not really being a princess here since it only include tech that’s absolutely necessary, but the main point here is there’s about $10-15k worth of content missing when comparing this $83k sticker to competitors.
some pics
I know at least one guy who has thrashed one during Off Road rallies in WV, OH & KY.A work vendor drives one, so got to see one up close. They look really cool, just not in my price range really. Plus it's another one of those vehicles that looks like it could go offroad, but you never see them lol. Similar to the Hummer and Defender.
GTFO!How was the rearward visibility? The split door design w the high mounted spare sems like it would be an issue.
I really like the look and idea, but the deal killer for me is you CANNOT RESET THE OIL CHANGE LIGHT YOURSELF!!! You have to go the dealership where they have a proprietary diagnostic tool that is used to do that.
The problem with that is two fold:
1/ there are very few dealerships in the US. Many states don’t have any. CA I think has five.
B/ If you change the oil yourself but go to the dealer to reset the light, some charge up to $350 to just reset the light! Because they want you to do the oil change at the dealer and so stick it to you if you don’t. If they charge $350 to reset the light, how much is the full oil change?!
Just found this:GTFO!
Seriously, there really is no way to reset oil change light beyond a dealer - no Forscan ODB equivalent a person can use??
If this is true it is my honest hope, and sincere prayer, that the the Ineos is an abject failure...though that is unlikely as even in failure these sorts of ventures too often end up being tax right offs or what not for their parent companies
Ridiculous. I'm with you, I like the idea of the Grenadier, but bullshite like this makes it a complete no-go...Just found this:
So a month ago they came up with the ability to reset service settings. $500 for a 2 year subscription, only runs on a Windows computer.
Whereas in my Bronco I just go to settings, maintenance, reset oil life. 10 seconds tops and it's free.
There is descent mode available- might be specific to the "rough pack" (includes locking diffs). Switch is on the overhead panel.Does it have a descent mode? With the Bronco the clutches in the torque converter will lock when the transmission is in M mode so there's no freewheeling on a steep descent. I haven't found any rep or salesman who can answer that question.
