Gnarly tailgate rattle
HeliPilot
Kenny
CT
2022 2.7L SAS
Put your seats in the down position and see if it gets better. Thats how I diagnosed my seats were rattly. I thought it was the tailgate too, but it was a combination of the seats and the rear hatch window on the hardtop. Of course there is also people with tailgate rattles, I just havent had that pleasure yet even though it sounded like it was the tailgate.
I know someone who removed the spare to diagnose a tailgate rattle, i think it was the little nubs that the tire rests against causing the issue.
After I diagnosed the noisy passenger seat, I slid it all the way back and the noises are gone. I'll just keep it there. It would drive me crazy on rough roads. Haven't heard it for nearly 2 months since I slid it all the way back.
Inletjunky
Manasquan, NJ.
2021 bronco
Had same problem on my outer banks. I added 35s this past fall but annoying squeaking noice from tailgate was there prior to 35s. As the weather got colder the squeaking became worse. The change in temperature creates everything to expand and contract. Colder weather will contract so all points on tailgate where plastic and metal meet were causing noise due to weight of spare. Btw. There was no noice at all when I removed spare. I purchased a tailgate reinforcement from rough county and just about all that annoying noice is gone since installed.
slohatch
Daniel
2026 Bronco Raptor
I have removed the spare and lubed all contact points and it has done nothing for the noise
luptanpitman
Los Angeles
'21 Bronco, ‘21 Polestar
Just wanted to report that my brand new bronco with 15 miles has the dreaded tailgate rattle. Oh MAN is it annoying. My dealer tried for almost a week to find exactly what was wrong before I took delivery.. They took the entire tailgate apart and they couldn’t diagnose the problem. Apparently they asked the local rep if this is becoming common and the answer was yes and that nothing currently can be done. I was told that Ford is collecting VINs to follow the issue and will hopefully come out with a resolution.
We isolated the problem to the spot inside the tailgate. They replaced the tailgate - which doesn’t have the tick in the tailgate anymore - but it’s now ticking inside the rear corner of the frame maybe where the door bolts on. I can isolate it when I’m sitting in the trunk and someone else is driving. I am over it - the new one isn’t as severe and with windows open and music on almost exclusively im gonna chalk it up to soft top truck isn’t gonna be without ticks n rattles.
Hbrichman
CA
Ram 1500
Did u try lubing the areas mentioned above? Worked for me.
I’ll give it a shot. Just drove it approx 200miles and over any/every bump the tailgate would make an incredibly loud thud. I can’t imagine driving it long distances until this is remedied. It literally sounds as though the tire is going to fall off.
Hbrichman
CA
Ram 1500
Brocno was dropped off this morning at my local dealer. The intense thudding/ratting has caused damage to my tailgate.. Dealer said its so bad that looks as if somebody backed into something... This is within the first 300 miles. Very upset to say the least
slohatch
Daniel
2026 Bronco Raptor
What did they say looked damaged
Hbrichman
CA
Ram 1500
They said the tailgate was creasing at the rubber tire bumper & that it looked like somebody backed into something. I don’t believe anybody backed into anything though; I think that damaged was caused from the constant thudding of the tire on the 3 1/2hr drive home
Herbie
Alex
Cleveland OH
2022 Badlands
That's nice to hear about the RC reinforcement plate, mine is in the mail, or will be any day now.
BroncoAdventures
KC
Livermore
2014 ford escape titanium ,1991 toyota 4x4 22re
I have this same problem and glad to finally find a thread with others - although the more people worries me they will claim normal. I've been to dealer twice and driven with service and techs in the back. they sent the below video to ford and everyone has acknowledged that it is not normal.
They told me Ford sent a few ideas of spots to lubricate and tighten. It's definitely in the cavity tho closed to the interior left side which is welded so they are running out of ideas - I want a new tailgate. The plastic panel does come off pretty easily though of course I have broken a couple tabs - the sound is exactly like the plastic screws pushing in and out a thread at a time but I pulled them all out and it didn't fix it so it is something else.
It can be replicated when I open and close the tailgate but it's most present driving over any road that isn't perfectly paved. - there is some level of stress or flex happening. The latest idea was the wheel/brake light mount screws which they said were loose but it did not fix it. They are keeping another day. Attached is a video of it when it was at its worst which is typically the mornings. it started after a few hundred miles for me as well.
I listen to this noise driving 100 miles a day . It’s so annoying. 😭
BroncoAdventures
KC
Livermore
luptanpitman
Los Angeles
That’s fascinating - why would that happen on some trucks and not others. Bad batch of rear gates that aren’t properly stamped or reinforced.
slohatch
Daniel
2026 Bronco Raptor
Took the Bronco back to the dealer and they found this. Hopefully will get replaced
I’m surprised they didn’t just say you bent it and go pound sand
