Global Window CLOSE issue with DDM
JBlanco
Julio
Charlotte NC
Based on the 1, 2, 3, 4...I think these are in reference to each door/window. If you look at the Global Open, which is on by factory...they are all enabled for 1, 2, 3, 4. This would make me think that a 2dr Bronco won't have 3 and 4 and just 1 and 2 but I cannot confirm since I have a 4dr and will be testing this out tomorrow morning (attempting to turn this on).
I think your theory is correct. I have a 2023 2 door and initially thought the personal 1,2,3,4 were related to the key fobs being allowed to global open close. I disabled 3 and 4 and was still able to remote open/close both windows with all three of my fobs. I programmed a cheap used third fob to the vehicle in case I lose one, I'm still able to program them without going to the dealer.
omi205
BoJack
Austin
IT WORKEEEEDDDD. BdyCM went perfect. Gave me a "write" issue on the PDM and DDM. Disconnected Forscan. Turned the bronco on/off. Reconnected Forscan. Checked that the BdyCM settings still saved (they did). Then attempted the PDM and DDM changes again, worked!!! Tested and windows all went down. Then all went up. Happy camper.
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
Going to try this. I will program BdyCM first then after successfully writing I will try PDM and DDM
JBlanco
Julio
Charlotte NC
BroncoDave24
East Tennessee
'61 Falcon, '87 F150 XLT Lariat 5.0, '01 F350 7.3L, '24 WildTrak
Remote Window roll-up programming worked on the first try for me. 2024 Wildtrak, version 2.3.60 Forscan and a OBDLink EX interface and a HP laptop running Windows 10.
vrtical
Doug AI
GSMNP, TN
Fords
Just got to get this to work on my 23 braptor. I needed to run a new profile after Forscan update for DDM and PDM changes to work. The BdyCM changes which I did first worked on old profile.
Agrod
SJ, PR
22 4dr OBX
I did this change, and it worked as expected. The windows go back up with the key fob, except for the front passenger's side window.
It goes down and up fine, but always rolls back down to about 3/4 shut, even with the normal window buttons for that particular window after triggering it to go up with the key fob. I have to do the relearn process for it to shut completely.
EDIT:
I'm not alone...
phubar
J
Tampa, FL
2020 Jeep Wrangler
Thank you for posting this. Could someone share a screenshot of their hex numbers please? I must have mistyped one of the digits because my windows go up as soon as I hit the lock button without having to hold it.
murrman
Sean
Toledo, OH
2024 2 Door Black Diamond
Sorry to resurrect an old thread, but I found this while trying to find out if what needed to be modified for the 2 doors was different than the 4 doors. I’m going to give this a go later today using the “easy” way of using the plain-text module (instead of the asbuilt). The only thing I wasn’t sure of is whether making the changes that way added the window open/close setting to the Sync 4 settings menu. Could anyone confirm whether or not it does?
Not sure if easy mode does or not, but in as built format there are two edits you make - one enables the function, the other adds the Sync option
murrman
Sean
Toledo, OH
From the spreadsheet, it looks like there are seven total changes to make the windows go up and down with the fob, correct? It then lists an optional eighth change to add it to the Sync 4 menu. I’m guessing the easy mode changes do the first seven changes, but the eighth one is still necessary to do in the asbuilt menu. On a side note, could someone who’s enabled the option in the menu tell me exactly what it allows you to turn on and off? Does it let you separately decide whether to allow the fob to roll up and/or down the windows, or is a global on/off for both up and down?
Sounds correct. If I recall, it’s distinct up and down, either/or
Ford Bronco Global Window CLOSE issue with DDM imag
murrman
Sean
Toledo, OH
Gotcha, thanks. This might be a stupid question, but I’m assuming you can’t just enable the ui using ForScan and then enable the actual feature in the Sync 4 ui, right?
