Global "close" from the remote does not work for my driver window
DenNut
Troy
Denver, CO
Using Forscan, I enabled the global window close option. It seems to work mostly ok. However, while the passenger window and both windows close just fine, the driver's window goes up partially and then stops. The only way to get closed all the way is to continue to hold the lock button on the remote until the window is closed. Does anyone have any ideas? is this what you have to happen as well? Do I have a warranty issue with that window that I need to get looked at?
UberGadgetFreak
Joe
Mt. Holly, NC
21 FE Bronco 22 FE Mav, 23 Mav Tremor, 03 Marauder
Had the same problem with my passenger front window.
Just have to reindex the window. Easy to do.
This thread has the info on how to do it:
Window Reset Procedure | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
DenNut
DenNut
Troy
Denver, CO
I did the re-index, and it worked a few times, but it’s back to the same behavior
