- Michael
- Apr 28, 2022
- 10
- 735
- 1,027
- Los Angeles, CA
- MBZ E350, supposed daily driver
- First Edition
ngry and Broncos get Grumpy. There's a whole series of memes and quotes waiting to happen here... I'm going to dust off my Disneyland Grumpy dwarf hoodie today!
This required a lot more work and $$$, which for me, was more than worth it.And how did you do that so that they turn on when you start? Inquiring minds want to copy this....
I swapped my AUX switches for something more robust, the SwitchPros 9100.
I used this SDHQ mount to replace the AUX switches.
I also had all of the wiring "swapped" to more robust wiring, just in case.
I used quotes because I left the OEM wiring and just added my own wiring along the same paths.
The end result was this:
All of the buttons do what they say, on/off and double press to strobe.
The last button marked STROBE is a master, so it'll turn ALL ON/OFF or ALL STROBE.
Everything is programmable through an app on your phone via bluetooth.
For instance, turn on at start, for which I have my amber fog and amber rock lights turn on.
I'm sure there's a way to have them turn off after a set time, but I don't think it can sense when you're in MOTION to turn them off.
There's a ton of settings you can play around with, I just did what I needed.
This version is the 8 gang switch, but the also have a 12 gang version and SDHQ has a mount for that, too. In hindsight, I should have gone with the 12 gang to future proof my setup, but for now, it's good enough for me.
