Fuel door adjustment
jbehrn
2024 Bronco
My recently purchased 2024 Bronco needs to have the fuel door adjusted because the hinged side scraps against the body when I open it.
I don’t trust dealers to fix the issue without damaging the paint - does anyone have a doc that describes how to adjust the fuel door flap?
Ducati1098
There is no adjustment. Something is either broken, damaged or not installed correctly
SierraBronco
It just pops out. I wonder if it got pushed in too far or incorrectly, causing the misalignment. It was hard to screw up though, even when cutting out the hole in fiberglass fenders.
PWillette
Parrie
Maine
Possible the arm got tweaked/bent.
jbehrn
jbehrn
2024 Bronco
Ford Bronco Fuel door adjustment IMG_3048
Image attached! It’s been this way since I purchased it new (didn’t know about it till my first fill up).
jbehrn
jbehrn
2024 Bronco
Door hinge:
Ford Bronco Fuel door adjustment IMG_3052
SierraBronco
Door hinge:
The hinge itself seems to just be plastic, so I’d expect there to be a visual if it was bent. I’d try popping it out and just check all around where it clips in to the fender to see if it’s seated all the way. It looks like it is from the picture but it’s hard to tell. Our pictures aren’t super useful as the white bronco has ADV fenders and the black bronco, well, it’s black. Little tougher to see.
Ford Bronco Fuel door adjustment IMG_7412
Ford Bronco Fuel door adjustment IMG_7413
jhunt47
arkansas
2024 bronco
Had the same issue and asked this about a month ago all I got was take it to the dealer. I don’t trust the dealers around me to fix this either so here is what I did.
Get a plastic trim tool and put painters tape on it.
Open the drivers side rear door and above the door latch body side behind the rubber seal is 2 bolts.
These bolts are for the rear quarter panel.
I loosed them wedged the plastic trim tool between the gas cap lid(closed) and the panel and twisted.
Tighten back up this gave enough clearance it no longer rubbed.
Bolts are 10mm
