Front lower control arm bracket bent. What to do?
broncoboyty
Ty
Wheeling this weekend I took a good hit to my passenger side front suspension and a rock bent the lower control arm mount. The rig drives straight and feels ok. But the tab is bent pretty bad.
How do you fix this? Does a new tab need to be welded on? Who would do this?
I am in denver Colorado.
Thanks
Ford Bronco Front lower control arm bracket bent. What to do? 20230618_103039
Ford Bronco Front lower control arm bracket bent. What to do? 20230618_124252
Ford Bronco Front lower control arm bracket bent. What to do? 20230618_124253
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Bend it back with a big adjustable wrench.
popo_patty
Caleb
Sacramento
kodiakisland
Arkansas
Used large vice grips to bend one back enough to remove LCA.
Flourman
Centennial, CO
2022 F350 Tremor, 2019 Beta 300RR
Looks like you have an aftermarket bash plate. The RCI comes the closest to that control arm bracket and protects it more. I was able to get mine bent back with a crescent wrench and hammer.
tobyw
Toby
Washington
2022 4-Door
Mine are also pretty bashed in, so much so that I can't remove the LCA... I haven't yet figured out how to make a repair...
Wilbur's son
Hesston, KS
2001 Ranger 4x4
I bent the passenger side rear lower shock mount inside tab. Used a 2-foot-long crescent wrench to straighten. Now have the FP rear lower shock mount skid plates.
So long as the alignment is ok leave it bent - it can’t bend again if it’s already mashed against the Lca
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
I upgraded from RCI to Talon's Garage front skids which protects these more.
