Front differential pinion seal leaking
Qtip
TX
2022 Bronco Badlands
Personally, I’d bring it back to whoever replaced the seal and ask them why they didn’t correctly perform the TSB Ford released. Tell them you want the fluid changed.
I appreciate the advice and will be doing that. I found the TSB number to show them
Qtip
TX
TSB if you anyone needs it
SSM 52278 2021-2023 Bronco - Front Axle Pinion Seal Leak - Built On Or Before 09-Jul-2023
Some 2021-2023 Bronco (non-Raptor) vehicles built on or before 09-Jul-2023 may exhibit a fluid leak from the front drive axle pinion seal. This may be due to operating the vehicle under high load. If leaking, replace the pinion seal following Workshop Manual (WSM) section 205-03A > Removal and Installation > Drive Pinion Flange and Seal. To prevent subsequent seal leaks, the front differential fluid must also be replaced using the revised specification Motorcraft® SAE 75W-85 Premium Synthetic Hypoid Gear Lubricant, part number XY-75W85-QL. Refer to WSM section 205-03A > General Procedures > Differential Draining and Filling. For claiming use causal part number 3254 with applicable labor operations in Section 3 of the Service Labor Time Standards (SLTS) Manual and M-Time. Reference this SSM article number in the warranty claim.
2023bronco
location
vehicles
Apparently, the service writers/techs don't always search for TSBs when a vehicle comes in with a leak. While mine was in for ANOTHER mic top replacement, I had them check a leak from the pinion or sway bar disconnect. They confirmed the pinion seal leak and changed the seal under warranty but used the wrong fluid. When I picked it up and saw the invoice, I told them they didn't use the correct fluid under the TSB. That's when they went looking for the TSB, found it, and changed the fluid.
So, be sure to tell them about the TSB because they may not bother to look for one.
Qtip
TX
That is exactly what they said when I asked about. They just diagnosed it and changed the seal and didn’t refer to the TSB. I took it back today and they are now changing out the fluid.
2023bronco
location
vehicles
Pretty fucking sad when the customer has to tell the dealership that a TSB exists. Ford's got problems, which apparently they think will be fixed with spiffy new decor.
FTBronco9
F-150
So, just found this leak on my ‘21 SAS OB (74k mi) when changing my oil. Now that I’ve read through this thread, I just have a couple of questions. 1) Has anyone changed this seal themselves? 2) Can this get fixed by the dealer for free, if I’m out of warranty and there’s a TSB?
Ducati1098
To answer your second question, no.
There is no warranty coverage past the base factory warranty, unless you potentially have an ESP that covers it.
A TSB doesn't extend the warranty coverage at all.
Denny Swift
Earth
718 Spyder, 992 GTS, Citroen 2CV, Husky FE350
Mine is leaking. I took it to my dealer. He looked at it and told me it wasn't bad enough to fix! And then he told me he was going to charge me $125 for his effort to look at it, even though Im still under warranty and I already paid him for an annual inspection!! I laughed and said there is zero chance im paying him and I'm done with his dealership. He removed the charge from my bill, but I'm never going back to that dealership. The next day, he sent me a request to give them a 5 star rating! You can't make this stuff up!!!
23OBX2.7
AB Canada
2023 Bronco
LOL you must be in Canada where this arrogant, entitled cistomer abuse is rampant everywhere, as are govt supports to many failing businesses.....no wonders everyone is terrified of CN vehicles and service.
orion
Jeremy
17' F-250, 17' Explorer
Dealers are a joke these days, well, except for dealers that have a @Ducati1098 working at them... 😔
Qtip
TX
Did you take it another dealer to get it replaced? It should not be leaking at all. Show them the TSB.
Wyld2dr
2023 2 dr Bronco; 2016 Audi A7 tdi
32k miles - front differential replaced. They indicated it was most likely related to the pinion seal. Front Differential failure is under the 5 yr 60k warranty.
They replace the entire assembly, not allowed to crack it open and repair.
