Front Diff is Toasted
Built2Wild
Bay Area
Motorcycle
After a trip to Death Valley I heard a squeaking noise while only applying the gas. When changing the oil, I noticed that the front diff housing showed signs of a leak. I took it to the dealer but decided to drive in 2H just out of curiosity and found the squeaky noise had ceased. When I got to the dealer I was able to pin-point the issue, today the Service Advisor sent me the message below. I followed up with a phone call and was told that the leak could have caused the issue since the fluid could have been low. I was also told to change all my fluid at 30k since I do get off-road at least once a month. Everything is going to replaced under warranty but what an experience!
“Technician found leak with front diff- drained fluid found metal debries in fluid. Took off diff case and found almost all bearings in front diff toasted. Per fords pinpoint test says to replace front diff assembly. I ordered one it is about 4-5 days out. You can keep rental until work is done. looking like mid next week for completion.”
Montana Bronco
Montana
Chevy
Cool that Ford is fixing it plus you got a rental to hoon around in for a week. Sounds like you are winning!
BAUS67
redneck
Central PA
.............................. I took it to the dealer but decided to drive in 2H .......................
Just a curious thought. Do you normally drive in 4A all the time, no matter the conditions????
Built2Wild
Built2Wild
Bay Area
Motorcycle
Oh yeah, the rental is all on the dealership during the repair. Capitol Ford in San Jose, I didn’t buy my Bronco there due to markups but there service department is top notch.
Built2Wild
Built2Wild
Bay Area
Motorcycle
I do drive around in 4A no matter the conditions but I don't think that caused the leak in front diff. I read on other threads of people having concerns or issues but I never had an issue. I think the leak could of happened when I was driving on the wash in Death Valley and changing the G.O.A.T Mode to Baja while not being at a low enough speed.
BAUS67
redneck
Central PA
I was not saying that caused it, just the way you worded it I thought that was the case, I did not want to assume. 😁
Built2Wild
Built2Wild
Bay Area
Motorcycle
No worries, I have seen contributors on some threads go over the top on responses to others. Who really know what caused the issue, I am glad it's being taken care of
BAUS67
redneck
Central PA
I've seen 2021 front diffs grenade, so yeah, who knows why, could be anything.
Roach011
James
North texas
23 Bronco Wildtrak
Just had my front diff replaced right before Christmas. Identified the front pinion leak and had that fixed earlier in the year. I'm assuming when the leak was fixed the front dif was not installed with correct spacing. My bearings and gears started howling a few months later, maybe 20k miles later. I drive a lot.
So far so good with the new front diff.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Yes, Ashley's front diff. grenaded. Probably search through her threads (Not her STIG photo dumps) and find some gnarly pictures. The term "grenaded" isn't hyperbole. Looks just like a bomb went off.
Zzoop28
A
2023 bronco
Mine was just replaced by the dealer as well, I had had the front pinion leaking since it was new.
BAUS67
redneck
Central PA
That would be the one I'm thinking of. :wink:
flip
Phil
IN
www.ruxerparts.com
Fords
There is less than a quart of fluid in the front diff. so just about any amount of leak raises the chances of catastrophic damages exponentially. While Ford says some seep or dampness around seals is OK so long as there's no drips. Due to the low capacity of the bronco front diff, no way would I take that chance. Even if you catch and fix a leak on these early, you really don't know how much you lost or if the bearing got hot between the time the leak started and was fixed. Bearings could've gotten hot enough to accelerate their failure but not go completely out and do the rapid disassembly thing.
If you do your own services, check this often as well as the fluid level. If you take it to a shop to have done, be sure to have them check all seals for seeps and leaks. Some places (we do it too) will clean off any wet looking areas, make sure the fluid in that assembly is topped off and notate it on the shop order so we check again next visit. Just remember, wet and full=OK, drip and low=not OK.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Are the diffs covered under the 5yr powertrain warranty?
