Front camera working intermittently
EgreenBadSquatch
EgreenBadSquatch
Washington
2015 F-150, 2022 Badlands Sasquatch
That’s all I needed. I’m a pro at removing the grill, I used to have Morimoto lights…just went back to stock.
Thanks. Looks like I’ll be doing this. I haven’t removed the grill yet. Any tips or mistakes to watch out for?
akturbo
Seattle Eastside
Its easy. Remove ~10 retainers to remove the top cover, 4 bolts for the grill, unclip the camera wire and hose (squeeze the clamp to release the hose connector), pull the grill straight out from the Bronco, best to pull the wire retainers from the grill to give you some slack, two bolts hold down the camera.
Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
It did. I replaced it myself and the whole thing took me less than an hour. Maybe even closer to 30 minutes. Haven’t had a problem since.
Are you sure the new camera did it or was it possibly just the wire was loose on original and you fully seated it during replacement?
EgreenBadSquatch
EgreenBadSquatch
Washington
I checked the wires before replacing and supposedly the dealership checked them also.
Jazer
Jessica
2.7 OBX
For me personally, the dealer checked all wiring and was fine. Replacement camera fixed my issue. It's been working great for over a year and the issue has never returned.
lauk101
MN
2014 JKU, 1973 Bronco
I replaced the camera myself after it sat at the dealer a week without being looked at, fixed.
Order Contents:
P/N​
Quantity​
Price Each​
Description​
M2DZ19G490C​
$ 60.22​
Park Assist Camera (Front)
Do you have a link for that price? The cheapest I'm finding it is about $300 online
akturbo
Seattle Eastside
You’re right, that’s crazy! Is there some supply/demand thing going on? The rear camera is still reasonably priced.
EgreenBadSquatch
EgreenBadSquatch
Washington
That’s insane. When I got mine it was only about $65 I think.
WheresMyBronco
Los Angeles
2023 Badlands
If your Fordpass account is set up, message me the VIN and I can check the last 60 days worth of codes the truck reported to the cloud. If it is happening sporadically and it does report a code when it happens, I would be able to see it in its history.
Would you be able to help look up the codes on my bronco as well if I send you my VIN? I took mine in for a repair at the dealer and they're saying they can't replicate the issue or fix it without a code, so I'm hoping this will help
Thanks in advance
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
Thanks in advance
Yea, send it over. I'll check it out tomorrow. Need details on what actually happened. Without them being able to replicate the issue or see a code that's active, they can't do anything. That much is 100% true.
