Forscan and 2023 models?
meffie
meffie
Raven
'23 WildTrak
I downloaded and tried this yesterday to change my tire size. I got into the programming and made the change. After that service lights came on and had a bunch of DTCs. Is this normal?
Yes. You need to reset the bcm and another module. Can't remember which other module. There is a thread on the step by step for changing tire size, or you can pull up a youtube video.
Edit: I think the other module is the 4x4 module, although I still can't remember the exact name offhand
Gorgar84
WV
Found It, thank you
meffie
meffie
Raven
'23 WildTrak
WakeSS
Georgia
2023 AGM Bronco Badlands SAS
Fyi Same error on a 23 via IOS app. So it hasn’t been updated yet either.
Guess i have to spin up a windows device.
Ford Bronco Forscan and 2023 models? 968799FC-F36A-40E9-B3C9-3F835B7692A3
WakeSS
Georgia
Just following up on my '23. Successfully changed double honk, amber DRLs, Bambi enable, and Sport mode. Windows 11 surface, Forscan ver 2.3:51 test 20230204
Forscan rocks! In the late 90's I paid hundreds to just be able to read codes and parameters. Now for $12 you get programming!
brtd
Iowa
23' BL, '15 LR4, '22 Beta 390-RS
Nice. I was able to perform those same changes using the previous test release on my 2023 (2.3.51.test20230108), though I didn't add sport mode. Any chance you tried disabling the auto start/stop? I couldn't get that to stick with the last version.
I hear you about the cost of this level of access in the past. I've had Vagcom for a VW and Audi and the cost of entry is in the $300+ range if not more. The IIDTool for my LR4 was just shy of $600. I welcome this change.
vrtical
Doug AI
GSMNP, TN
Fords
Just tried FORScanSetup2.3.51.test20230204 release and it works for my 23 Braptor, previous .108v did not recognize it.
WakeSS
Georgia
I did not try disabling auto stop/start.
I’ve actually been pretty impressed with Fords implementation. Waaay better than my wife’s GM. Still not crazy about potential wear and tear.
The tricking the status by setting the angle has me a little apprehensive.
Just how I drive it may kick on once a drive.
George Ellis
George
Cumming, GA
23 Bronco Badlands Soft Top
Forscan 2.3.51 just went to general availability.
willettj
2023 Ford Bronco
Let me know if the new version will help.. I read in another thread that the auto start/stop disable via Forscan is not working for 2023 models.. I attempted the change in the Google sheet changing to 00 and it did not work for mine, still need to try to 02 option. the notes for that line are a bit ambiguous.. "Start / Stop: 00=Disabled 01=Enabled, Angle Inhibit Enabled 02=Enabled, Angle Inhibit Disabled" << no code given for the Angle Inhibit Disabled
Shannon
New Mexico
2022 Badlands
I have been able to do a several things on my 23 Wildtrak (double honk disable, seat belt minder off, door ajar chime disable, key-in ignition chime off, amber DRLs, 2 click panic button). However, auto start-stop disable didn't work.
ETA: I have a Superchips Flashcal that doesn't recognize my 23. Hopefully Superchips will provide an update soon...
Amber DRL's? Do you have a link for the spreadsheet on that?
illverado
Cory
700whp stick shift 2000 silverado 23 basesquatch 2dr 7mt
Just downloaded new version last night and using the noob option selecting disabled, A.S.S. still works on my 2023 base sas 7mt. Help?
illverado
Cory
Ford Bronco Forscan and 2023 models? 499D800F-E864-409C-976D-13347A0825A3
