Forscan help needed. 2023 Wildtrak mid package
dav_woot
Washington
2023 bronco wildtrak
I installed an amp and an 8 in sub. When I went to update the modules on Forscan and was scanningfor the first time, my computer freeze/ locked up due to a heat sink/ fan warning. The computer ussaully works well but I was in the garage on a very hot day. Once the temperature went down I tried again. It had so many codes when I press the ignition button for aux power. I hadn't changed one module, just connected and the computer powered down without me he able to press the safe to disconnect button. It won't start, says zero gas, the e brake won't disengage, collision warning, active task warning, etc. I'm not by it to check them all.
I was able to connect to forscan and save my modules. I was able to update the ACM and got the amp/sub working. The ABD module won't update because it says there are a different number of blocks in the one I'm trying to upload a d write vs the one displayed. The BdyCM won't load either. It get to about 35% and shuts the writing process down. I went to motorboat service amd downloaded the file for my VIN but it won't upload amd write the modules I'm having problems with. Any help is appreciated.
BigMeatsBronco
Allan
2021 FE 2 door
wow, crazy, don't fret there is a way to upload or download the as built, it has to be in the correct format.
BigMeatsBronco
Allan
2021 FE 2 door
you could also carefully look at the as built data on the couple of modules that are not rebooting and manually change the few lines that don't line up with the OEM as built.
