Baja Bronco
2Sun AZ
22 Ford Bronco, 20 Ford Raptor
Just down loaded the the new update for Forscan and got a new license's and after 3 attempts got it to log all the modules and up date the body control module to eliminate that terrible double honk. 23 Outer Banks non SAS.
Any issues getting Baja mode? Any errors?
SillyPosition
Silly
Israel
None
What exact version is that that works for you?
kbernard
OBX,NC
23 Tacoma work truck
I downloaded the V2.3.51 version and I just got a new license. My dongle is the ELMconfig OHP with the switch for HS and MS Can. It did say it was not an approved dongle thou it worked on my 21 Bronco and my 21 Ranger with zero issues. It did take me 2 times to get it to read to get all the modules to pull up. After the first attempt had to delete previous save and pull to get a fresh read.
Free2Roam
Heading back to the desert
2023 Bronco
The button no longer indicates whether it's enabled/disabled. It's always off, all the time, it doesn't matter whether you push the button or not. I mean, you can push it if you want to but it doesn't do anything besides light up.
I am coming at this a couple months after your post. I have a 2023 badlands and used the current version on forscan.org, 2.3.52 I think, and an obdlink ex. I disabled auto stop and when I started my Bronco after the programming change the ASS button had the OFF letters lit up on the switch and the system was disabled without me touching the button, which is different from your experience.
I forgot to push the button during my test drive and see if it was still possible to activate AutoStop with the button, I will check that tomorrow.
Tex
Cliff
San Angelo
It's certainly possible, things may have changed between 2021 and 2023, could be that the code and functions are somewhat different now, I have no way of really knowing 🤷‍♂️
Cgon567
Carlos
New York
2023 Bronco Wildtrak
I'm getting unable to read vehicle information error, I am using the latest version and OBDLINKEX to connect. Could the Procal tune be an issue? Any suggestions
Cgon567
Carlos
New York
Ford Bronco Forscan tips for 2023 Bronco ...  Get the latest beta from Forscan 1686589280945
How can I find the strategy/calibration name or part number? Its driving me crazy
Danh63
Dan
Ohio
BMW X4, BMW 840, Chevy Trailboss
Migo
Roy
Houston, TX
www.instagram.com
Following. Same connection issues with FPC on 23 Badlands.
James Cole
MX
Badlands Sasquatch (hopefully)
Can five blinker lane change be added to the 2023s?
AlliB123
Allison
St Louis MO
2023 Badlands Previously: 2022 Big Bend
Since me and electronic data retention have a sketchy past, I printed my "as built" module data/values.! It was only 22 pages.!
Me and my ocd ass are totally doing this 😂
Derrick
Derrick
Ontario, Canada
2023 Bronco Raptor, 2010 Audi R8 V10
Any update to change to 5 blinks for lane change? The spreadsheet I am viewing has the info crossed out and the reference numbers do not match to change the code. Thanks
